Make: Nissan
Model: S13 Silvia
Milage: about 145,000
Transmission: 5 spd manual
Colour: black (will probably need respray)
Complied? YES
RWC supplied? n/a
Currently registered? rego until 9/08
Price: $9000
Contact: Nick - 0410-803-199 or PM me or email me on [email protected]
Comments / Modifications:
-Genuine sr20 k's converted to manual with a proven 185.3 rwkw on 18psi.(still running stock computer and injectors)
(with old tubo setup/tuned length exhaust manifold and t25g ball bearing turbo and stock exhaust)
NOT YET BOOSTED UP OR DYNO TESTED WITH NEW EXHAUST AND TURBO SETUP!! HOWEVER IS NOTICEABLY MORE
TORQUEY ON 7 PSI OF BOOST. SHOULD BE ITERESTING WILL POST AS SOON AS IT IS TESTED!!!
-Modified close ratio 5speed s14 gearbox.
-140XXX original klms.
-400hp fuel pump
-Sard adjustable fuel pressure reg (rising rate)
-Custom oil catch can
-Rubber vaccume hoses replaced with simota Silicone hoses
-Annodised oil temp sensor mounting block (NEW)
-new oil hoses and annodised oil fiitings on tubo(new/all speedflow fittings used)
-Top mounted T3 Bush Bearing turbo(like new)
-Stainles steel top mount tuned length exhaust manifold(new)
-38mm external waste gate with screamer pipe(new)
-3"cat back exhaust(new)
-Alluminium radiator overflow tank
-Front mount intercooler kit fitted
-Battery relocated to the boot
-Earth kit fitted to engine
-32mm rear sway bar fitted
-BLITZ boost pressure,exhaust temp,oil temp and water temp gauges with memory recall(fitted)
-GReddy boost gauge with adjustable warning and memory recall
-FIELD digital fuel adjuster
-S14 ignition coils fitted
-DNA motorsport boost control valve (new - not fitted)
-Electric thermofans fitted
-Sony CDX-22S single din head unit (not fitted yet)
-JBL 4x6" front speaker 200watts each
-New battery (heavy duty bosch)
-Interior retrimmed in creme & Black with black stitch (gear stick area needs work)
-Momo steering wheel
-Momo boss kit
-Momo gear knob
-Apexi turbo timer
-series 1 s13 silvia headlights fitted
-Serviced every 5000kms using genuine nissan parts
-Brake pads replaced (front and rear 6 months ago)
-Exedy extra heavy duty clutch with 1200kg pressure plate (12 months old)
-Power windows
-Power mirrors
-Climate control
-Central locking
-Power antenna
-Tinted windows
-NO RUST
PROBLEMS:
-Oil leak from gearbox tail shaft seal - i have the new seal - genuine nissan seal
-Small dent behind drivers door
-Paint chips on front and rear bars - patched up - still some chips tho
-Damaged rear quarter due to being hit in a car park (has been sprayed over)
-Various small dings and scratches
-Car will need respray
-crack in dash
NO TIME WASTERS!!!!!! Have only had car 3 months. Would also be open to swaps (preferably r32 skylines..selling this to start saving for a GTR tho)
If the chrome wheels aren't you're thing, i can put the stockies on instead.
Looking for a fairly quick sale. So make an offer on it guys
Images:
Edited by Black Widow
https://www.sau.com.au/forums/topic/199996-no-longer-for-sale/
  • 3 weeks later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
