Nick, from personal experience I got my apprenticeship by door knocking. I walked into places and asked to see the person in charge. Seeing people face to face and letting them know your keen can be a great personal selling point. I had a few documents incase they were interested, photo copies that I could leave with them ( as a reminder). Be well rehearsed so if they ask about what you've done and what your looking for you can answer sharply and confidently. Openings are always out there it's matter of seeking them out and not waiting or hoping they'll come to you. It worked for me on several occasions.
Good luck.
I had many years in Kalgoorlie, if up north is similar it's a good idea to have tickets even if it's HR, fork but definately elevated work platform if your looking at TA work. Dogman also worth doing. It can be expensive gaining these tickets but you can claim some back on tax and you'll recoupe this in no time earning them big bucks up north.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
