Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
From the measurements all seems to checked out ok. RDA is making a set of standard 310mm as we speak... will hear from them soon.
Hopefully will have a good news on Monday
  • Replies 548
Posted Images
cool hope they get them made shortly my front rotors are shuder now and geting anoyed with it. hope its good news with the rotors, have they said if they will b doing the slotted and dimpled ones or just standered.
Sure I will let you guys know. At this moment it will be standard (plain) and slotted, as slotted is basically plain rotors with some machined slots added in.
Not sure about the grooved yet, if the dimples are done from the factory then it'll be a challenge to machine it down to 310mm without ending with half a dimple at the edge of the rotor... depending where the dimples are positioned.
Ok, group buy 32 started:
- twogtrs (waiting for payment to clear)
I will also start a list of R34 GTT owners who wanted the front 310mm plain/slotted rotors.
The number here will determine the final pricing as I'm trying to get the best price as possible for let's say a list of 5-10 pairs of modified 324mm to 310mm rotors, so let's start the list:
- raps86
- decim8
- raps86
- decim8
MEEEEE!!!!!
SLOTTED!
Hi Rianto,
Could you please quote on a pair of slotted RDAs for the V35 including postage to Brisbane 4113.
Thanks!
will do soon... give me a few mins...
- RobMz (waiting for payment to clear)
R34 GTT owners who wanted the front 310mm plain/slotted rotors:
1. raps86
2. decim8
3. vidospace
4.
5.
Add me to the list, how would these compare to dba 4000 series? (i've read the thread about the cracking)
front & rear slotted pair GT-t
We haven't had any report of these cracking. Most cracks happens either on cross drilled rotors when used on the track (a common trait) or around the little return slots near the edges on other brands.
I wouldn't worry about the rears as for R34 GTT has the same rear as R33 Gtst which has already been available easily.
1. raps86
2. decim8
3. vidospace
4. Yo-Yo
5.
Sweet, any idea of availability for these?
I'd like to get my r34 up and running asap
a PM with pricing for the slotted rotors would be good so I know what I'm up for
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
