Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
The rest of you from group buy 39 should be getting your rotors soon... If it's not there by monday pm me.
Update to Group Buy 40:
1. Muz (payment cleared)
2. scorp (payment cleared)
3. SevenAngryPenguins (payment cleared)
4. Josh_TypeX (waiting for payment to clear)
cankas, will send you quote later, gotta go now to beat the traffic to work...
All payments below for Group Buy 40 is cleared:
4. Josh_TypeX (payment cleared)
As a couple of you above required your rotors ASAP this lot of 4 orders has now been sent off to RDA for processing.
The closing date 23rd November is now for the next Group Buy 41...
hey,
could you please PM me a quote on slotted rotors all round and EBC Greens all round
R33 GTS-t (Series 2): F=7693S 296mm RRP $305, R=908S 297mm RRP $190
cheers
Edited by PSI.33
Finally got around to installing mine yesterday, havent had a chance test them properly yet but they feel good so far, and look awesome. Thanks Rianto
Hey Rianto
Thanks for that mate...got mine today
will get them installed next week or so and then i will tell you how it goes
33drifter, dont forget to bed the pads in, new or old pads regardless, should bed them in.
Could some one please explain by that ^^^ comment?
From DBA tech support
Basic_Initial_Brake_Bed___MotorSport.pdf
http://www.rdabrakes.com.au/index.php/pads.html
at the bottom of the page is there bed in procedure.
Hope it helps, it is important to do it
Edited by cankas
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
