Looking For Some1 To Fit Turbo
Guest trikdoutvl
hi ive got a vl with a rb20 in it and i was wondering if any would be interested in upgrading my turbo for me. im looking for a rb25 turbo to upgrade to, so if ur intrested and wanna make some money please pm if u would be interested or if u have a rb25 turbo in good nick.
Edited by trikdoutvl
https://www.sau.com.au/forums/topic/200765-looking-for-some1-to-fit-turbo/
I have one complete with lines and turbo snout elbow, thing that make it lots easier to fit. $400.
I think you should DIY as it's not hard at all with the basic tools. You need some oil and coolant and some gaskets for the turbo prefferably or some ultra copper exhaust gasket goo. Give yourself a day to do it and you will cruise it in.
Guest trikdoutvl
cool brockaz thanks for that im guessing uses are in perth??
properly wont be for a few weeks cause i got motorvation to prepair for
thank you for the feedback every1.....
im new to this forum n i dont even have a skyline but i find every1 is friendly and helpfull. thanx
at least u have half a skyline lol its skyline powered
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
