With a shorter range of motion your goin to really give your quads a flogging as you can go heavier..
the deeper you go the more you get your a$$ involved
i use to think i couldnt physically go any lower but i tried doing it with lighter wieght.. Sh!t i went back to just doin 40kg squats so i couild learn to do it properly again
it takes some getting use to but will be better in the long run...
Weight or no weight, I mean it quite literally when I say I can't squat lower, at least not without spreading my knees further and leaning forward, which would be horrible for your back.
yeah just need to work on your mobility... hips/hams etc too tight... your only slightly above parallel, not everyone can drop their ass to grass straight away
technique wise concentrate on looking up and really pushing your chest out... first motion is to hinge at the hips and thrust your ass out backwards before you start bending at the knees... your doing pretty good though... just don't rush the set, you look to be in a bit of a hurry
Trozzle - Ghosty gave you the exact advice you need.
camera angle or whatever is crap.
that is not a proper squat.
Nick has given you the reasons why you can't get any lower..
other than that..
You are loose - either that weight is too heavy for you (which it would be if you get to proper depth) or you don't know how to brace yourself.
Take a much deeper breath in and hold it before you go down.
Spreading your knees out is fine.
so is leaning forward some more.
Instead of the bar going up and down in a straight line, it is going in an "S" shape as you wobble your way trying to find depth.
search for "goblet squats" on youtube and do those any chance you get to help with flexibility/mobility to help get in the hole properly.
Shoes - what are you squatting in? if sneakers - get rid of them..
if you have a pair of Converse All stars, squat in those.
www.mobilitywod.com is a great place to learn about mobility.
I'm willing to bet that you have shit flexibility in calves, ankles, hamstring, hips and butt.
Those half squats you are doing are going to cause you knee problems as you add more weight to the bar.
You are not built any differently to anyone else (except tanlges since the poor kunt doesn't have knee caps) so instead of saying I can't get any lower, find out what you can to fix it.
When you bench press, do you lower the bar till it touches your chest, or do you go halfway and back up?
When you do curls, do you go curl half way up then bakc down or all the way up?
No different for squats.
Just a suggestion, maybe try doing dumbell squats side by side and see if you get a better ROM out of that. I can take this movement ass to ankles and my flexibility is not great. Given there's less to worry about with balance / core strength compared to normal squats, it may help to reveal whether your issue is in technique or flexibility? They still work the quads and glutes plenty...
Give front squats a go.. start light, like really light
How are you supposed to hold the bar? I've seen people either cross their arms or have their hands under the bar, both of which are stupidly uncomfortable.
either or, when using the crossing of arms method make sure you sit the bar on the meaty part of the shoulders
with the wrists are under the bar u need to get some flexibility in your wrists
either way suck it up :nyaanyaa:
Like this :P, another vid from the vault, again full range of motion - it is paramount.
http://www.youtube.com/watch?v=DuYn6hXuFkk
Edited by GHOSTrun
You're best to do it in front as your more prone to shoulder injury doing anything behind the neck. That's not to say you shouldn't do it behind your neck, but the muscles worked for both ways are almost identical so I would take the form that is less prone to injury :thumbsup:
As Dan said, people can be more prone to injury doing behind neck. However, the actual occurrence of this when done properly is very low. I've been doing it behind neck for years and years without issue. The key is to get your technique and flexibility downpat, before you start stacking the weight.
I do prefer behind neck because it's more focused on the delts and your chest muscles are less likely to get involved in the motion, compared to front. I see a lot of people struggling on the last couple of reps when doing it in front, leaning back to activate the chest muscles, which probably isn't terrific for your back and becomes closer to an incline press. Behind neck on the other hand is much more strict and forces your shoulders/tris to do the work. Keep a straight back, push your chest out, keep the bar flat and bring it all the way down to your neck. One leg out front with knees slightly bent will make it easier on your back too.
More important than in front or behind, is your width of grip on the bar IMO. Closer grip = more triceps, wider grip = more shoulders.
Finding good form for Deadlifts (without kneecaps, with popping patella tendons) sucks! Trying to find a happy zone.
Split 2x callus's yesterday/today - going to have to purchase some "softcock" gloves :/ Really effected todays workout.
20th session completed in 40days since starting (including Xmas+NY gym closure, plus half week off with bad back after moving house), thats good I feel. Average would be 90mins per session. Noticing that Im leaning out a bit (loss of flab) and have definitely gained decent strength.
In a few weeks time will setup a split routine as I'll probably only have a little over an hour to workout @ 6am prior to Uni classes.
Edit: started taking Scivision Xtend yesterday, 2 scoops in 1Lt water taken throughout the workout. No problems with energy levels. eating v.healthy meals too :) happy with that. Every good workout / every good meal is like a $$ in the bank - in a year from now will be a good investment.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
