If you want them that low i would look for the wing mounts from a 4door non turbo. dunno if its the same as a 2 door non turbo but they are about an inch shorter than the mounts on my GTT which im guessing are shorter than the GTR. Dont think it will make the GTR wing stick soo far back but will definately bring it closer to the bootlid.
jus did a quick search and found this: http://carmate.com/product_details.php?pro...W&p_id=9679
look the same do u think?
Have seen this before, def lower but does'nt protrude past the boot like the other one, thanks for looking though.
I've seen this lowered kit thing before. Can't remember where. i'll take a look.
T_T that GT-R has serious problems. Don't wanna say anything cause its an Australian R34 too lol NSW.
Bec... hmms... she might see this lol.
its an imposter! lol.
That wing looks awesome lowered... wouldn mind to know how its done either!
maybe it's just me, or it's on a funny angle,
but I'm pretty sure GTR front fenders flare out a little more than what's in the pic...
I'd say the lower stands are Do Luck items:
http://www.do-luck.co.uk/images2/3w.jpg
http://www.do-luck.co.uk/images2/6w.jpg
http://www.do-luck.co.uk/r34gtr.htm (UK link)
http://www.do-luck.com/ni_sky_bnr34.html (JP link)
The site lists them as carbon rear wing stays
Awesome! thats definately it. Thanks for your help, i had a pic of the Do-luck kit but it had an aftermarket wing which threw me.
Does anyone know if theres a Do-luck dealer in OZ?
lmao i have that GTR as my desktop screen saver, didnt even notice :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
