I'm not sure if i have asked this before or not,
I got a bosch 040 fuel pump installed in my car a while back, since then i sometimes have to turn the key a couple times to start the car,(not always) i told the person about this who installed the pump and they said it was fine and that theres nothing wrong, i'm just curious cause with my stock pump i never had to turn the key more then once to start the car, the car ALWAYS started nicely with the stock pump.
thanks
i do that sometimes and it still does it, i was told to let it prime for only a few seconds, oh well as long as theres nothing wrong for me to worry about
thanks
theres a few things that could be causing that problem. Leaky injecotor or blocked? fuel pressure? cranking speed in the tuning. My guess is a blocked injectors or broken o-ring...
My guess is the non-return valve wasn't re-installed with the new pump (no dramas, mine wasn't either), just means you have to start it before the priming stops or the fuel flows back into the tank. Prime for a couple of seconds and start it before it stops priming.
thanks
bro my car has sard pump and reg and has the same problem,,mine is easer to start when the cars warm,,but when its first start of the day is takes a couple of goes,,is yours easyer when its warm,,?
Priming - is when you flick to accessories, and let the fuel pump whine away; its drawing fuel into the stator and pressuring the lines. It will go quieter or quiet when done. Now you hit "start".
You shouldn't need more then one hit of the starter motor.
I was under the impression everyone did this :P
040's I believe come with drain back valves, 044 don't.
  • 3 weeks later...
thanks
Check if holding pressure, connect inline fuel pressure guage, get friend turn on for you watch fuel pressure rise and hold? or drop off? check drain back valve, ok? and right way fitted, install one see what happens?? if still no good look further was ok before but not now, whats the stock pump/internals like compared to repacement, bigger in/out pressure may drop to rapidly before your turning key to start?
I was under the impression everyone did this :D
my 044 came with a banjo style anti-drain back - but i replaced it with a dash style screw on from motorsports connection
are the 040's built in ?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
