Item:
ADVAN Super racing rims incl. tires
Unknown
Condition:
Rims - Very good condition
Tires - 70 - 80% all around
Price:
NO LONGER FOR SALE
To Fit: (What car)
Most 5 stud - 5 x 114.3
Melbourne, south eastern suburbs
Contact:
PM or call/SMS 0416 623 381
Comments:
I have decided to put my rims back up for sale again as I didn't manage to sell them last time.
They are Super ADVAN racing rims, 17x9 on the back and 17x8 on the front.
Rims themselves are in very good condition for their age, and would come up mint with a polish but are currently still very shiny. They don't have any gutter marks but a couple of the wheels have little marks, about half the size of a 5c piece so nothing very noticeable.
Offset for the wheels are +35.
The rims have good tires all around, MARSHALL on the front and I can't remember the brand of the rear tires off the top of my head. Tire profile 225/45/17 all around with about 70 - 80% tread left so still have plenty of life in them yet.
Pictures of the wheels on my car don't have centre caps, but I have the original centre caps at home and will be included at sale.
Wheels look awesome on any Skyline. Tried them on a friends R33 an they looks awesome!
There is a few pictures below. If you have any more questions just let me know.
:P
Edited by abu
https://www.sau.com.au/forums/topic/201092-super-advan-racing-rims-incl-tire/
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
