why do you want a cams approved one?
cams approved doesn't mean its street legal, any half cage is street legal aslong as the car is reg. as a 2 seater
edit:"note all j-spec brand cages aren't cams approved due to the thickness"
Edited by [Michael]
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3577011
Sam, your posting about your rollcage at 3am??? Go to bed and get some sleep man!!!!!! LMFAO
Anyway, try Maitland Fabrication? I know a guy with an early Zed, and he stripped the interior etc then gave it to them to build the cage. From memory he said it was about 2000-2500ish? That is cams apporved and not non removable side intrusion bars but under cams ruling, they can now be made removeable.
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3577430
for a decent cage thats CAMS happy for racing, your looking at 3k+ from most people, i recommend LF performance, maitland, and if you want really top shelf mark bourne, but expect to fork out big bucks..
do forget driving it on the road and A class rego tho, it won't happen, rally reg only for you
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3583662
mmm i think i might leave the cage idea for now, u dont need a cage for drifting at barbagello anyway, ill guess il have to try not to crash till i have more money :P
Or just get the half cage . . atleast its some protection
https://www.sau.com.au/forums/topic/201102-want-a-rollcage/#findComment-3585483
