LOL i am hardly an expert!
Ive only had it on there for bout 2 or 3 weeks and been playing with it tryin to get it somewhere right.
just went and had a look at my settings and atm they are-
set: 40%
gain:27
set gain:6psi
its holding boost pretty well but needs more fine tuning. also been hard cause ive been trying to do it on my own...
My cars mods are just 3" turbo back and a K&N panel so pretty stock...
hope that was of some help to ya! :P
oh also just adding the peak boost with those settings was 10.3psi....not sure of the rpm(bit hard to drive and look at it lol)
Cuz ive got it installed and set by UAS, i didn't really wanna touch it so before i do this how do i check wat the original settings are currently? what do i turn or press on the EBC? :D thanks alot by the way
to check the set just turn the nob but dont press it in...it will display the current setting and go away on its own.
for the gain just press the mode button once, press it twice for set gain, and all the other settings are the warning and limiter and peak boost etc...
let me know what they are set to atm and what kinda boost ur getting...
:P
Set: 45%
Gain: 20%
Set Gain: 8.7psi
Those are the high boost settings which makes around 11 psi boost like 10minutecar and also drops as much as he does (to about 9 psi)...
Do the other settings affect the boost or performance wise at all or are they just extra features such as warning alarm and etc?
Also does the setting you have spike boost at all? And if it does spike the warning alarm will go off right?
Edited by R33Turbo
I havent even been in my car since yesterday so nah havent tried em out yet. It sucks in the rain i get to much wheelspin in second gear...
With the warning, i have never hit it as ive been conservative with my settings as not to overboost.
But yeah according to the manual the warning light comes on and the unit will lower boost by whatever you set the limiter to.
so at this setting u gave me it reaches 10.3 psi max?
If i wanted to reach about 11 psi with the boost not dropping below 10psi..how would i set the settings? im not too sure how to do this percentage setting thing
what i would do is just turn the knob up a couple of % at a time. dont forget u gotta press the knob in to actually set it.
just dont go upping the gain or set gain too much. It should only be adjusted up like 1 increment at a time....at least once its close to being right anyway
Have you gone for a run with those settings tho??
It probly is.... like i said im still playin around with it and have only had it for a couple of weeks... ill give ur settings a go tomorrow and see what happens.
It was hard for me to tell if it was dropping off much as i couldnt look at the guage as i was driving and was only relying on the peak boost and last boost features on the EBC.
If the boost is dropping off try increasing the gain setting by 1 or 2 increments at a time. just keep an eye on the peak boost. its a good idea to clear it before trying out new settings.
Where abouts are you from?
Yeah the last boost tells ya what it was as u let off the accelerator, not a drop in boost. I really just need to get a mate to come for a drive with me so i can see whats happenin. Like I said before ill try out the settings u mentioned and see what i get with them...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
