January 12, 2008) They were fastest in qualifying and were leading the race from the sixth hour onwards. After that, Australian team, VIP Pet Foods (Tony Quinn, Klark Quinn, Craig Baird and Jonathan Webb) took their Porsche 997 GT3 RSR to victory in the third edition of the TOYO TIRES 24H of Dubai.
Great to see the Australian Teams doing so well overseas, With Shaun Junipers 997RSR coming in 4th outright and 3rd in Class
We didn't expect to be able to reach such a result, but after qualifying, we knew that we were quick here. We were well prepared for the rain after the few races in Europe in which we have participated. Whether or not we will be racing in the other races of the 24H SERIES, depends on how much pet foods we can sell
Hopefully the Good international results for the Australian Teams can help gain more support for the re introduction of the Bathurst 24 Hour.
https://www.sau.com.au/forums/topic/201291-congradulations-vip-racing/
yer what a car it is those RSR are just great to watch and the sound they make
Yeah they are stunning pieces of machinery. Still waiting for one of my mates to get theirs, to have a serious look around one.
the Junipers have ordered a second one so it sounds like they are serious about the endurance racing, and VIP have given up their Carrera Cup this year to focus on the 24hr races aswell
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
