I have 2 fully assembled reco'd, ported and polished, big cam heads available and one complete not reco'd head as well.
All covers, plenum, throttle bodies, injector plate etc are available also.
email [email protected] for info.
Cheers
I might have a complete r33 gtr head for sale soon.
It has everything, CAS. plenum, injectors, throttle bodies, all the covers, exhaust manifolds ect ect. Nothing has been modified so you can do what YOU want to it, not what someone else wanted.
If I can get $2500 for it I will sell it otherwise i'll just keep it.
intersting, seems we shall negotiate.
u have pm :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
