Item:
Neo RB25
* Garrett GT35/45 Turbo with custom heat sheild
* 6BOOST hi-mount Manifold
* 48mm wastegate
* Bosch 750cc injectors
* Fuel Regulator
* Eagle 8mm leads
* 4inch Dump pipe
* Screamer pipe
Toowoomba
Item Condition:
Perfect condition only got bout 40000km on the motor
Reason for Selling:
no longer needed
Price and Payment Conditions:
$5000 ono
Extra Info:
I had this motor in a vn commodore
Built By Steve at Superb Mechanical
Tuned by matty Spry at P.I.T.S.
Makes 441hp
Runs 10.66 @128mph down the 1/4 mile but there was definatly room for some improvement
Pictures:
Edited by 57QCK
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/
so thats just a bolt in rite, my cousin has an r33 gtst and he is lookin for a motor because he has fried a piston, so what will we need to get this motor running, eg computer and other stuff, plet me know, may be intersted
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3582821
only if i had thing money.. 10 sec neo, very nice..
free bump
10sec motor in a VN Commodore, probably running auto with trans brake, stally etc
Won't be a 10sec setup in a skyline, but either way good value for money!
Good luck with the sale.
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3583074
yeah buddy usin a auto with transbake but dont c why it wouldn't be a 10sec setup in a skyline as they r bout the same weight as a vn
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3585468
try getting a 10 second pass using a manual then you'll see why.
and i would think vn's are a fair bit lighter than r33/r34's.
r32's might be around the same weight, but you would still struggle to get a 10 second pass with a manual.
good luck selling bud.
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3585613
hey mate i got a mate that has a dato sunny with a sr20det and manual and he pulls consistant 10sec passes he is now building a gsr lancer with evo 6 motor i think
nice set up good luck with the sale
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3586414
err..point of that last post?
...anyways considered selling a complete setup ie engine, loom and computer? obviously the motor may be capable of running 10's but without the tune it wont really do anything. youre making good power from an interenally stock motor!
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3586923
nice.... 400+ hp on stock internals... is it alryt????
my rb25det is running low compression. so was thinking to rebuild it to handle more power and maybe a bigger turbo....
but didnt have enough money for all that....
if this motor will give that hp in my r34. and last long........ is this a ryt chice guys?????
how much money im looking on the top to put this motor in.
i got a Hsk pro ecu... maybe i can use that for this one...
anyone got any suuggestions please....
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3591843
it is fine to run that power as im usin a 50/50 toluene/bp ultimate fuel mix and it was tuned by matty spry. if you've got a 34 then your gearbox should be fine and u can use that ecu, all you'll need to do is bolt it in and get it tuned. the motor is still in my car and running if u want to see and hear it running.
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3591999
how much boost was that power level made at ? its prity impressive on standard internals great luck with the sale mate, if this came by a month ago i woulda grabed it and put some forged rb30 botom on it :) but iv already got all the parts i need apart from the rb30 block :(
good luck with the sale "very good price for the power level" not sure how long itll last on standard internals and im prity sure this will make around mid 11s on a r34 skyline if you could get grip or even a lil lower..
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3592003
oh ok.... some ppl say it wont last long with this internals......is it true?
correct me if im wrong.
i live in melbourne. where is ur place?
well i've had it running for bout 1 1/2 years and never had a problem with it, it all depends on who tunes it and running the fuel mix helps and its always been looked after properly. i live near brisbane.
https://www.sau.com.au/forums/topic/201606-neo-rb25-motor/#findComment-3593025
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
