hey guys, unfortunately my car has to go as i need something a little more practical that i can lug my band gear around in. i've owned this car for just over a year, bought it from autostyle in sydey and as far as i know i am the first australian owner. car is in beautiful condition, only a couple minor scratches, wheels are pretty scuffed tho and there is a bubble on the dash. The car runs beautifully and i've had no trouble with it since i bought it. Car is virtually stock with only a couple quality mods and has rego till june.
Make: nissan
Model:skyline bnr32gtr
Milage:110000km
Transmission:manual
Colour:white
Complied? yes
RWC supplied? yes
Currently registered? yes
Price:19000
Contact:nick
Comments / Modifications: r33gtr wheels, cat back exhaust, sydneykid's whiteline/bilstein full suspension kit, apexi power fc, turbo timer, 212rwkw
Images:
https://www.sau.com.au/forums/topic/201609-fs-93-r32-gtr-110000ks-white/
  • 1 month later...
  • 2 months later...
bump!
decided that i didn't wanna sell it, but now i do again. no swaps though. post or pm me if anyone's interested. car specs still the same, though recently had injectors cleaned and retuned, now much bigger mid torque curve. cheers lads!
yeah stock turbos, running at i guess 13 or 14psi, ie boost restrictor removed. i was on the verge of getting some gt-ss's but have obviously decided against spending further on this car.
the dyno graph is from when the FC was first put in. AFR is now at a very lean 12.5 (apparently this engine for some reason just doesn't want as much fuel as other rb26's) as i said before, injectors have been cleaned up and car has been retuned since, resulting in more midrange torque, but i don't have the graph for that i'm afraid though might be able to get it. cheers!
Edited by shredder667
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
