Item: x2 Garrett 2860r-5 turbos (707160-5005)
Age: Brand new, still in packaging
Price: $2500
To Fit: GTR
Contact: PM me
Comments: Come complete with uprated 15psi actuators and .64 rear exhaust housings.
Edited by Godzilla32
https://www.sau.com.au/forums/topic/201653-fs-brand-new-garrett-2860r-5-turbos/
  • 1 year later...
arrr why would you sell them them for more then you can purchase from a shop
i have been priced 2400 brand new plus install??????
Good one guys! Maybe because the thread and therefore the price is well over a year old!
Just wondering, which workshop did you get this price from, as I am in the market for some new turbos preferably the ones stated
most sponsors ask around 2500 IIRC
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
