im guessing its an aftermarket pump, and when your running low on fuel, the sound of it pumping or buzzing echos more in the emptier tank making it more audiable.
Fuel types arent going to change the sound
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/202002-fuel-pump/#findComment-3588470
Dude. When its full! Not empty....
Either way its wierd...when its full...you sure its not just in your head?! :)
https://www.sau.com.au/forums/topic/202002-fuel-pump/#findComment-3589624
Thanks guys. its been like that for awhile now i got no idea on how to get to it either( PUMP) As i was the first owner in australia and it just came like that.
Like i said everytime the tank is full it does this how would i know that this is a aftermarket item or just needs a replacement?
Would be over the moon if it was aftermarket hahaha :(
https://www.sau.com.au/forums/topic/202002-fuel-pump/#findComment-3590163
is it a stocker? only when filling up? does it make that sound when you prime it everytime or just filling up which is quite strange. if it wasnt doing it before then first assumption is its on its last legs.
hopefully someone with more experience can shed some light
Mate i only really notice it when im idle, cant hear it over the exhaust
https://www.sau.com.au/forums/topic/202002-fuel-pump/#findComment-3590169
a dyno will tell you if your fuel pump is not meeting the needs of your air to fuel ratio. otherwise if you start feeling fuel cuts through the rev range i'd start considering a new pump. but if not, you have nothing to worry. :D
https://www.sau.com.au/forums/topic/202002-fuel-pump/#findComment-3590462
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
