Item:2 x RB25DET NEO motors
Age:1998 & 1999
Condition:pristine
Price:$2,500.00 each
To Fit: (What car)Anything you want.
Contact: (0425) 249 891
Comments:
Hi Guys,
I've had these motors sitting here for a while now.
I really don't want them to go to waste.
First one is in a 1998 Stagea, Tiptronic.
has 140k on it and can be test driven in the vehicle.
This motor will be sold with loom and ECU etc.
It can also be sold with a flywheel if necessary.
Second one is out of a 1999 Stagea, Manual.
This motor is already removed, it had about 60k on it
This motor comes without ECU and Loom, but with everything else.
If someone desperately needs the ECU/Loom contact me and I will sort something out.
Both these motors can be supplied with a fitted 2WD sump and pick up to suit. Or the AWD sump that is on them now.
I also have a Series two Stagea that I am parting out at the moment, so if any one needs something just give me a bell.
If I can be of any help or something is unclear feel free to contact me
Andrew
Edited by gianavel
https://www.sau.com.au/forums/topic/202088-rb25det-neo-motors-for-sale/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
