Thanks, I'll have to cobble something like sonicii did, will report back
Agree! I still believe I have the quietest 400kW+ R33 in Australia. -
ah gotcha ill go remeasure again, thanks for all the tips. when i measured the TPS 5v reference voltage, i put my multimeter leads on 5v power and strut tower bolt, it gave me 5v with boost sensor disconnected and with boost sensor connected it gave me 1.4v. ill try remeasure again this time with volt meter both on the 5v reference and TPS signal ground wire.
By Darussalam · Posted
R34 meter cluster non turbo auto (neo) is compatible when fitted with manual transmission. Currently the Speedo meter is no reading when accelerating -
Wow, the latter ones instagram shows amazing work. When you got it back, do you feel like they replaced all the springs and components with new ones? Or they restored the old exisiting ones?
