:blink: HeyGuyZ...
When i Turn 18 ill sell my R33 Gts-t for a GTR. ill have just about 30k if lucky. :D
Please Guys!! help me out here i love the small light look on the r32 GTR's they just look amazing and so do the r33gtr's
,i dont know what to get? Could you guys help me out with some difference's about the cars and what your choice's
would be?
:( CHEERS!!
joosteN^ ;)
https://www.sau.com.au/forums/topic/202509-r32-gtr-or-r33-gtr/
:blink: HeyGuyZ...
would be?
:( CHEERS!!
joosteN^ ;)
33's are newer and you will most likely find one in better nick easier. IMO R32 GTR is what id take but its personall preference, If u can find a 32 thats in good cond that is stock for a decent price id say do it
^^ Heh! Yeah I go R32 GTR but thats personal preference, R32's are cheaper to buy and I prefer the shape.
(Good point) If you can find a stock one. I was at JSA Imports and they had quite a lot of GTR's and I test drove the Stock 1. Sales guy said it was probley the best one they had.
I find in my area there are a lot of R33's which just got a bit too common and I wanted something different.
It doesnt hurt to pay abit more for a better condition on an older R32.
Yes its personal choice, I like the look of the R32, which is why I bought one, but being older you will probably tend to have more niggleing problems with them, and its the little things that give you the s$#ts when they go wrong, the R33 is probably the better choice as it is newer but it really comes down to personal choice. Goodluck!
FIRST OF DAMN YOU AND YOUR CHEAP INSURANCE IN PERTH!
bastard....
if it was me, i would buy the 32 in a heart beat. why? because i was going to buy that, but a riding of a 30000 dollar car and n.s.w being as f**ked as it is, ima have to wait untill im 25 ( will probably buy one before hand lol ) which is a bitch. i love the shape of the 32 and the fact that 33's are so common.
good luck with what ever you go.
Hey again all! :D
I liked the r32 alot more then the others. yea its cheaper etc but i just thought getting a r33 would be good cause its
earlier model.
i think i'd just go r32 gtr. its allways been a favourite.
AS A FIRST CAR!!! not sure over the r32 gts cause its RB20 engine. ill just drop a rb25 in it for the sake of it ;)
joosteN^ :(
good luck with either. but a bit of food for thought is r32's are old when i bought mine the first thing i did was replace all oil and fluids timing belt andthen a large oil cooler they get hot fast.
r32gtr's are also an inch shorter and at least 50 kg lighter depending on what aluminium upgrades it has on the front end
good luck but remember any gtr is maintenance maintenance maintenace =money llucky for us there is sau with group buy's :D
First lets face it if it was'nt for the amazing r32 the name GTR would not mean anything to anyone.
Second point of the 3 gtrs not including new r35 which do you think would be a collectors car.....r32.
Saying that both are good but what you put into a r32 you really get out. so performace wise r32 will amaze you.
GTR...Got To Race
hey all ;)
yea when i do end up with a GTR when im 18yo. it will be used alot on the track. and mainly for cruises on the streets.
id still have my r32 Gts hopefully for the km's use when driving everywhere i.e work, mcdonalds :D
joosteN^ :(
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
