gday,
bought a Blitz sbc-ID the other day and tried to install on my 33gtr, all electrics are fine but i think ive messed up the vacuum hose piping. my mate has done a couple of these before but on s15's, he said that you just put the hoses from the stock boost solenoid, onto the new solenoid and all should work well.
but it didnt work, can anyone give me instructions of what to do in reards to the pipes from the standard boost controller (pcm valve), do i need to block some things off?.... the controller didnt come with a manual..
- ive searched high and low but nothing for a gtr boost controller install, burn me if i missed it.
anything will be appreciated.
thanks
Edited by depalma-bcnr33
https://www.sau.com.au/forums/topic/203145-blitz-sbc-id/
In the manual that came with the device (assuming its not stolen >_< I'm ~100% sure it clearly shows how to connect to a RB26 twin turbo.
EDIT: It does, reading material...
DSBC Boost Controller Manual
SBC ID
You haven't mentioned whats actually not working.
Edited by GeeTR
https://www.sau.com.au/forums/topic/203145-blitz-sbc-id/#findComment-3604916
Stock boost gauge is in millimeter's of mercury (mmHg) x100
+7 on the gauge should be around 13.535psi
Shouldn’t be hard at all. Check the PDF, simply move boost lines from old unit to the new solenoid. Be sure to keep the old solenoid plugged in. Be sure to have a pressure reference feed to the control between throttle body and intake valve.
Edited by GeeTR
https://www.sau.com.au/forums/topic/203145-blitz-sbc-id/#findComment-3605282
thanks for the advice, still not working...
when i leave the stock solenoid connected (pcm valve) the blitz unit starts making a clicking/crunching sound, doesnt sound healthy... despite all efforts still wont go over .7 bar, the orignal boost guage that measures in mmhg has been removed and the reading is coming off an aftermarket apexi guage.
ive tried switching the hoses around, with and without stock solenoid connected... im starting to think the boost controller solenoid is fu*#ed,
the guy with the s15 i was talking about before blocked a line going to his cooler piping or some shit, is there a need to do that on my car??
https://www.sau.com.au/forums/topic/203145-blitz-sbc-id/#findComment-3623451
hook actuator line to OUT on the solenoid and hook a boost line from the intercooler pipe (PRE INTERCOOLER ONLY) to IN on the solenoid.
Forget the factory stuff, forget the factory solenoid it CANNOT be run with the BLITZ unit.... use the new line supplied.
https://www.sau.com.au/forums/topic/203145-blitz-sbc-id/#findComment-3623654
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
