Hey guys,
My driveway has a bitch of a curb. My car looks like a 4WD at the moment, and it still only has a few cm of clearance when I'm pulling in. Add an aftermarket bodykit and lowered suspension, and I'll have to park on the street, something I really want to avoid.
I've talked to a Suspension speciallist, and they told me that airbags will not fit on the skyline because there is not enough room up the front. My question is, what else can I use to raise the height of my car while still retaining a car that handles as if it was on rails?
Thanks,
Rhys
https://www.sau.com.au/forums/topic/203347-automatic-height-adjustment/
I know how you feel mate. My driveway would have to be the worst for a car enthusiast. I live on a main road and there wouldn't be any chance of using ramps.
Just adapt to your drive way. My car's pretty low, but I can still manage to get out. Just experiment with the ways you can go out of your drive way. At the moment, I'm reversing out at the maximum angle my drive way will let me and making my rear wheel go over the curb so that it clears the lowest section of the road/driveway. Doesn't make any sense. hahaha. You'll understand when you see it though. I'll try and get a picture up of how I get out of my driveway.
Kinda makes sense adam. I was always going to go out on an angle, cos its a wide street and very quiet, take up as much of the road as i need. A picture would be really helpful if u've got one. Now I just have to afford the coilovers...
Here are some pictures of my driveway. As you'll see, its bloody stupid, but I can still manage to get out okay. There's also a picture of how low my car is. Only sometimes would it scratch the fuel tank.
Is your driveway as bad as mine?
post-32186-1201517899_thumb.jpg post-32186-1201517917_thumb.jpg post-32186-1201517959_thumb.jpg
I use the curb to get my car over the lowest part of my way out.
Here's how low my car is..
Yeh, that is very bad!! Mine isn't a square like that, but it is still steep. More like a crazy triangle. and it's the same all along my side of the street, but the otherside is fine. Kinda weird, here is a photo of it. It looks decieving, but that may be because I am so used to it, only curb I've had!
YAY!! There you go. It doesn't look like much, but it will definately scrape when lowered with a body kit. So, I could come out sidewards, that might help a bit. Or park on the street, but I don't want that!! I won't even park in the private carpark at work, someone might scratch it!! I park out the back now, next to a written off VL Commodore. Makes my car look so much better!
I would swap drive ways any day of the week! The lowest you can go legally is 100mm from the floor, but sometimes, people go to about 80mm ground clearance. I reckon you can get up that pretty easy. Just go up/down at a really sharp angle. So much that it looks like you're parallel parking. haha. No really, your driveway isn't that bad. Take up as much room as you can by driving on an angle.
Once your two front wheels get on the driveway, you should be able to straighten up and it should be fine.
Front is normally much lower than the back so get someone else out there with you and practice the angle. Take it really gentle until you have one front wheel and one rear wheel up on it. My driveway looks much steeper than that, I take 3-4 turns and drive up the nature strip to make it in :laugh:.
Someone has made it in once without scraping it with 1 or 2 turns, I've never been able to repeat it without scratching my front bar.
And I'm 11.5 or 12.5cm off the ground (roughly) on the front bar and you have to use angle at some petrol stations to get in.
If you go below 10cm at any point its a defect so I'd be careful, that and you will have so much trouble at some peterol stations and other places that you will fear all driveways/speedhumps :D
Personally I reverse in but I think your driveway might be easier going forwards.
yeh, i reverse in as well. But I can drive up onto the neighbours verge and reverse in. My aim is about 100mm (or 10mm :-)!!) at the kit. I'll try practising my angles, and my verge and my neighbours verge are all paved, so I can take up as much room as I could. I hate speed bumps as it is, and try to avoid them as much as possible. Just have to avoid places like Hillaries, where you can't go around the bumps. I'd prefer to have some sort of height adjustment, but oh well, you get that!
lol get hydrolic suspension ahhahahahahhahha and bounce away like a pimp :D:P or just get a quote from a concreter to redo your drive just how you want it prolly cheaper than hydrolic and air bag suspension LOLZ
OMG you guys are pussys, Try driving up an mountain to get to ur garage.. No bullshit my drive way it about a 45 degree angle.
Tein once made adjustable height coilovers adjustable in car which raise and lower on a button, $4,000 tho.. Thats what I need, your just crying about nothing
Edited by DECIM8
Yeah, from what I've seen my driveway's pretty bad, but I still manage to get up fine. Sometimes it would scratch, but with practice, it all works out. The worst part about my driveway isn't the driveway itself, but the road, gutter then driveway... if you know what I mean. It goes into a little 'ditch' which it scratches everything. That's why I use the curb to get around that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
