hi people
i drive a 180sx sr20det n after not drivin it for a day i went to drive it tonite... i started the car n as soon as i did the car seemed to missfire n wa jus dumpin fuel. ma mate said it could be the coolant temperature sensor but i wa jus wondering if anyones has got any ideas?
i would be greatful for ur help
cheers
https://www.sau.com.au/forums/topic/203392-car-not-running-properly/
Does it still do it constantly? Most cars run rough after a while if they havent been used. If the problem is constant, then there is a problem. Try doing an ECU diagnostic on it, see what the problem is. I cant see how its the Coolant Temperature Sensor, that just controls the temperature gauge!!
GeeTR, play nicely!!
Rhys, fair nuff sozzles :D
Sam a good start though for a SR20 in a Silvia issue.. would be the NissanSilvia.com forums; with the lack of more info, I did think u was taking the piss ;)
Does it only play up when you start the thing? Does it show any rudeness at all when driving? Is it only when cold / hot? Stock fuel pump?
BOV - how do you know your BOV is staying shut? Do you mean so when your driving, or again.. when idling after starting it? More info, gets more help :P
haha sorry mate im abit new to this... iv cum from england wer we are limited to drivin 1.6 standard cars at my age lol
the car wont drive at all, it jus will not go at all its goin in to a garage tomora coz i dont hav a clue!
cheers for ur help
cheers for ur help
sounds like faulty or not plugged in AFM
got the car looked at today the main fault wa the safc 2 settings had reset themselves but now alot more problems hav come up... im gettin a big list tomora of them all... cant wait :)
only had the car a couple of months aswel
cheers for ur help anyway
much appreciated
Thats generally what happens when you buy used!! We've got a Holden WB Statsman HDT at work, needs $2500 work done on it!! Thats the first one, the owner has another exactly the same needs the same amount of work. When we called the customer to let him know, his answer was... ... ... ... ... "...Is that all...?" Wish I had that much money!! Good luck getting it all fixed though
yeh its pretty crap int it... wish i had the money 2!
got the list today not happy at all... who ever did these mods must of been brain dead... theyv used a heater hose for the turbo drain hose n its got a massive kink in it n thats jus the beginnin...
ill need all the luck i can get!
good luck wi urs m8
You'll get that alot. People will try to modify their cars, but have no idea what they are doing. For example, they think all rubber hosing can be used for fuel...
At work we had a Mustang come in, and the owner had blocked off the heater core with a Sidcrome 75mm 1/2 in extention bar. And a Holden WB Stateman has a vaccume line leak fixed with a nail. WTF? Try to think out all your modifications, and do them with a little common sense. It may just save ur life!!
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
