  • Replies 40
Damn all those cars in one day!!
That yellow 355, the driver doesn't mind putting the foot down, my friend on his bike gave him a good run one night and no I am not suggesting that you should try this :ermm:
They were all Autostyle cars. I mingled in there little group. The gong was packed with modified cars and cops, hence why i didnt go all the way up to the beach. These pics were on the way there and back.
Oh, and the 355 thrashed the shit out of it, it was awsome. The GTR was going pretty hard to.
Edited by NRV155
https://www.sau.com.au/forums/topic/203401-gong-cruz/#findComment-3608435
i went to the gong/lighthouse yesterday :ermm: saw heaps of cars, cops were EVERYWHERE, when i left they blocked off the light house so no one could get in, and undercover's in pajero's and falcon GTP/BOSS 350 (?) pulling over [P] Platers, bonnets up giving out defects
saw heaps of skylines tho, nice ones too!
did the stanwell tops and nasho run on the way home, damn it was fun!!
lots of other skylines, s15's and motorbikes all round :)
https://www.sau.com.au/forums/topic/203401-gong-cruz/#findComment-3608618
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
