Hey,
Got a full M spec kit for sale
Front Bar: $50 (Scratches + Modifications to fit front mount) - SOLD
Skirts: $75 (Slight crack on the bottom of passenger side)- SOLD
Rear Bar: $100 (Immaculate just resprayed not more than 2 or 3 months ago)
Mob: 0422 184 997
or PM Me
Located in South East Brisbane
Pictures are pending
Edited by Benno-
https://www.sau.com.au/forums/topic/203539-fs-m-spec-r32-bodykit/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
