I need some help figuring this out.
I have the R34 GTT vented fenders and they are 20mm wider than normal. I'm trying to order the Racing Hart CXR's.
Front 19x8.5
Rear 19x9.5
On the racing hart website it says the offsets for a R34 25GTT are...
Front 18x8.0 +35
Rear 18x9.0 +38
I have no idea if that means they are flush or not.
I'm looking to have my rims fitted flush with the guards... so what offsets should I use if I'm going 19 inch rims 8.5's and 9.5's? Any help would be appreciated. Thanks!
Hey mate, try using this calculator:
http://www.1010tires.com/WheelOffsetCalculator.asp
Type in your current wheels, after market wheels and you'll see how much more/less they stick in/out. Just keep playing till you get something you like then go out hunting for them wheels! :)
Good luck with your search, anymore questions, feel free to ask.
Type in your current wheels, after market wheels and you'll see how much more/less they stick in/out. Just keep playing till you get something you like then go out hunting for them wheels! :worship:
Thanks adam but I've seen that before. I can't use it because I don't know what the specs are for stock R34 GTT rims and the stock GTT rims don't sit flush. Also, I'm getting new front vented fenders that are 20mm wider than stock. Does that mean I subtract 20mm from the front offset? For example, if my front was 19x8.5 and offset was +30 with the stock fenders then I would need to find +10 offset rims if I get the vented fenders. I don't know how that works.... do I need 225 on the front to make clearance or will 235's or 245's be ok? Would 265's be alright for the rear on 9.5's?
Edited by chak8080
Lets just say your standard wheels are 6.5" wide and have an offset of +40 (not sure what they really are, but just going with standard r32 wheels). At the moment they are IN the standard guards by lets say 20mm. To have the wheels flush with the standard guard, you'll need wheels which are 6.5" wide and with an offset of +20, 8" wide with an offset of +39, etc. But since you're having the wider guards, you'll need 6.5" with a 0 offset for them to be flush, 8" wide with a +19, etc.
Remember that this is for your wheels themselves to be flush, with the guards, not tyres. Having tyres will make the 'package' stick out a little more if you're not planning on stretching some tyres.
Hope that helps... at least a bit. haha
Ok, so what your saying is that an increase of 1.5 inch on the width of the rim equates to +19mm (38mm/2)?.. in respect to that an increase of 0.5 inch would equate to +6mm (12mm or 13mm/2)?
I read somewhere on SAU that says the following is the best set up for a R34 GTT(i don't know if this is for a 2Dr or 4Dr).. Rims sit flush..
Front 8.5 +32 offset 225 tires
Rear 9.5 +38/35 offset 265 tires
If that's the case then I can use this as a base. Since my front fenders are going to be 20mm wider would this be right..
Front 8.5 +12 offset 225 tires or 9.0 +18 offset 225 tires
Rear 9.5 +35 offset 265 tires
Would that make the front flush again?
Does anyone have a ER34 GTT 2Dr that's running 19x8.5 19x9.5?
Edited by chak8080
Front 19x8.5
Rear 19x9.5
Front 18x8.0 +35
Rear 18x9.0 +38
To match 18x9.5 +38, you will probably then need 18*9 +12 with those extended guards to sit flush?
Yes, as far as I know, that should be correct.
18x9.5 with +38 will sit in the same position as the 18x9's with +12.
i dont have 19s but ive got weds 17 with 9 front, 9.5 rear, and +35 offset allround, and they look shmick and tucked nice under the
guards
Do you have any pics?
Ok, I thought I had it but now it's getting confusing... If I go off of Racing Harts website it should come out to this..
Front 18x8.0 +35 to 19x8.5 +29 (-6mm for 0.5 increase in rim width) to 19x8.5 +9 (-20mm to bring the dish out to fit flush with the 20mm wider fenders)
Rear 18x9.0 +38 to 19x9.5 +32 (-6mm for 0.5 increase in rim width)
Should I leave like 3mm or so clearance to maintain my turning ability? I want my tires to be slightly tucked so the rims don't hav eto sit perfectly flush... just flush enough where it looks 'full'.
jesus... I never knew sizing rims could be this difficult. It would be nice if they sold my PCD here in Korea so I can do test fits... but since I can't I don't want to waste money sending rims to and from Japan until I get the right fitment... these rims are expensive enough!
Does anyone know the stock setup for a 2Dr R34 GTT? I think the rims are 17x7.0 all around and +30/35 offset all around?? Someone correct me please.
Edited by chak8080
I agree, wheels are expensive and you want to do it right the first time.
With the troubles turning, it would really depend on how low your car is and how stiff your suspension is.
'Flush' for you could mean tucked for me. Can you get a picture of where you would like your wheels to sit? Cause when I say 'flush' I'm thinking...
R34GTT standard wheel specs are 17x7.5 +40
Use that as a base when using the wheel offset calculator.
2dr and 4dr use the same specs. I have run 8.5 and 9.5 +35 all round and still have a bit more room to move...say 5-10mm
If you are running wider guards +20mm then subtract that from what is recommended...I would personally be a bit more conservative and maybe subtract 15mm instead of 20mm...
With those guards you should be able to run 350z or even GTR offsets (have nice dish!)...approximately
8.5 +15
9.5 +20
Best to get your guards on first so you can measure how much room you have to play with based on the wheels you have on now...
If you need some ideas of suitable offsets for stock guards, have a look at my collection >_< Click on the archived months as well.
http://www.n15m0.blogspot.com
8.5 +15
9.5 +20
If you need some ideas of suitable offsets for stock guards, have a look at my collection :D Click on the archived months as well.
Hey thanks n15m0! Thats what I was looking for.
Nice! That's what I mean by flush too butI don't know if I'll rub or not from getting the wrong tire size. I don't want to strech them too much. So either I'll go with the strech or I'll just have the rims tucked a bit more.
Ok guys, this is what I'm going with.
Racing Hart Type CXR
Front 19x8.5 High Disk +21
Rear 19x9.5 Low Disk +35
It won't sit exactaly flush but good enough I guess....
Now tyres... I'm was looking at either the Eagle F1 GS D3's or the Falken FK452's. Front would be 225 or 235 and rear would be 265. Does anyone know if the tyre sizes will conflict with what rims size's I'm getting? I don't want to do any modifications, no rubbing either. I don't want my GTT to sit high like a 4WD car... just low enough to make clearance on the tyres so there'll be no rubbing. Any thoughts?
Are those wheels for the wider guards as well? The offset seems pretty high? Sorry, but I'm not all that familiar with skyline guards.
What I usually do for fitment and tyres is, make the wheels flush with the guards and get tyres that are about the same width. So an 8.5" wheel measures 215.9, but closes will be 215mm tyre for example. Not sure how good this will be for performance and that, but yeah...
Yep, I went with Racing Harts measurments for a R34 GTT... Front 18x8.0 +35 Rear 18x9.0 +38. I then calculated the front... being 19x8.5 +21 offset will give me 8mm more on the inner clearance and 20mm more on the outter. The Rear I chose 19x9.5 +35. That'll give me 3mm less clearance on the inner rear wheels and it'll extend the dish 9mm more. So far, I've found a lot of GTT owners using +35 offset for the rears and had no problems.
now I just want to figure out the right tire sizes without having to sacrifice performance or having to mod guards or having this rub. 215's would most likely make a loss in performance... I think I'll jsut go with 225 in the front. The rear is either 265 or 255. Racing Hart suggested 255 on a 18x9.0 so 265 on a 19x9.5 might work out.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
