  • Replies 54
i paid just under 2k for them. which gtr are you talking about? hmmm... i was quite sure that the spherical mount was for the front struts. i found this set of hks too. they are for the gtr 32 as well. they fittings look the same.
yes hippy, the purple set is actually a set of HKS hipermax coilovers. i'd think theyd be hell hard too. i'll keep u informed of the ride when i get them. steve, what is your view?
I love my ohlins on the road. Firm enough to make a pretty huge difference to handling, enough adjustment of the damp to go from traction to drift or soft, infact too soft for my liking:)
Hippy has been for a ride in my car, perhaps he could give you a passengers perspective?
Guest Jason Abz
Actually on a seperate note, Dirk diggler (GTR.CO.UK) does a lovely strengthening set for the interior. Not as obtrusive as a roll cage as it sits on the floor in the rear above the transmission hump and up the sides where the seat belts are beside the front seats. The extra stability in cornering is noticable as it reduces body `flex` on the chassis/car,
jas
jason! which particular ones did you have? did you have the same ones in the pic? and do you know the spring rates? hehehe when you say "HAD" does that mean you took them out? if so why? what about the underbracing that hks kansai do? do you or anyone else know much about that?
hks lower brace kit
Good swaybars make a massive difference to the handling - makes chassis much more neutral whilst cornering. I also found front and rear strut (edit) braces give that little bit extra, and are a nice addition. Swaybars from Selbys (whiteline) fitted cost about $500, so they are very affordable suspension mod.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
