thats each right...
No there is currently a full set of lights. Both fronts and spots . Buy now all expenses . $501 buy now. Just make sure you use air and package size . All can be found on import monster. No cost to join then browse . Body parts & kits . Nissan then headlights you will find them . Good luck .
https://www.sau.com.au/forums/topic/203952-s2-headlights/#findComment-3630588
