Hey guys, This has been happening for a while now... Everytime when i flat foot past 5,6,7rpm my car feels funny like its struggleing or something? ive changed my spark plugs but im not sure wot its gapped to. The current mods i got so far is Pod,Full 3'inch turbo back with high flow cat exhaust system.. and a HKS SSQV.. I rememba when my car was stock and when i flat foot the car would full funny, like its choking or something i duno... has this occured to anyone b4?
Thanks, Geraus.
https://www.sau.com.au/forums/topic/203974-is-this-normal-when-i-rev-to-7/
miss firing is most probally the answer.
check sparkies first if tats not the problem then coilpacks...
happen to me tooo...
get ngk iriway7 or iriway8(or equivalant). this sparkies are made for japanese cars like this. do go trying out stupid sparkies like iridium. cause me a headache....
Hey thanks so much guys :D yeh i think its a miss-fire, Due to the plugs.. but the thing is ive changed... I'l try and regap.. them.. They are irdium ones .... Sorry whats PFC? im confused there :D ? oh and yeh its a 33...
Edited by geraus
plz don regap ur spark plugs(cheap way to do it)... its an ancient tool tat ppl use 10 or more years ago... who ever ask u to regap doesnt really know wat they are talking about.
i got lectured by a mechanic saying tat everyone is asking him to regap the spark plugs... he say he rather not do my business when u got a proper item design to eliminate the problem.....
getting a plug is not expensive.... $35 each for ngk iriway7 or 8
Would this be the same solution for the R32 GTS-t with turboback exhaust, aftermarket cat, fmic, pod, stock everything else? I think mine has those iridiums as well, if i go by what the owner said, which so far was all true.
you have no idea what your talking about.
Regapping plugs is neither dodgy or "an ancient tool"
Its a well known fact that many skylines with mods will not run the stock 1.1 plug gap. buying expensive iridums at $35 each will not solve any problems either. Just get some BCPR6E plugs and check the gap is 0.8mm
all plugs should be checked with feeler gauges to see if they are what they are rated at... just cause it says 0.8 or 1.1mm on the box doesnt mean it is;)
Hey, i dont get it? so is it ok to regap or not? because i dont wana BREAK my motor? LOL? ... And what is the correct mm to gap to? 0.8? ot 1.1?
oh and sorry what brand is "BCPR6E " im guessing its NGK? so when i go buy some plugs all i need to give them is that code right.
Thanks so much guys!
Geraus.
Edited by geraus
Apexi power FC is what PFC stands for a ECU
Geraus.
Its fine to regap, just make sure you do it properly.
Yep just give them the code for the spart plug and they can give you the right ones. So as an eg: I use NGK 'BCPR6ES' which are factory gapped to 0.8mm.
Edited by abu
This thread my help you out a bit with understanding spark plugs, gaps and model numbers: http://www.skylinesaustralia.com/forums/Sp...gs-t104405.html
Also recommends what's good to use for your motor etc
Edited by abu
don't gap iridium plugs.
the tip is very fragile.
Just go to supacheap and buy 6 copper plugs with the code above, with an 0.8mm gap. (they cost about $4.50 each)
while you are there, ask for a feeler tool to gap sparkplugs.
then as said above, check them.
lol i use a small flat head screwdriver which tip is 0.8mm.... since im always gapping plugs for other ppl i use this.. but yeah feeler guages shoudl always ben used to CHECK the gap of your new plugs... 9 times out of 10 the gap is correct but every now and then there is a misgap
Sorry whats PFC? im confused there ;) ? oh and yeh its a 33...
apexi power FC ecu, also get your timing checked and if the timing belt hasn't been replaced get that done also ;). another thing that may help is getting your car put on a dyno for a power run so you can check the air/fuel ratio , just remember your r33 (s2 im guessing) is 10years old now , small things like the fuel pump may be getting tired :)
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
