hey guys and girls,
just put a new steering wheel with boss kit on the car, and the indicators dont automatically turn off anymore? im not sure if its coindicince or not, because i dont have a license and dont drive it, but i only just noticed it while reversing it into the garage.. i dont see how changing the steering wheel could do anything because isnt the turner off thingo in the steering wheel coloum cover and part of the indicator switch or something? any help appreciated. thanks
https://www.sau.com.au/forums/topic/204202-indicators-not-turning-off/
im not 100% sure with the skylines but have a look at the back of the wheel that u pulled off and there might b a piece that unscrews and gets put onto the boss kit. i know when i done it on a vl the indicators wouldnt work and found that we needed 2 swap that part over. hope that helps
DAMMIT - This is what happens when u buy shit from autobarn. FFS.. it was one for an R32. came with the wrong plug in the box, prob not even ADR approved.. ARGGHH... this is like the 3rd time im gonna have to pull the stupid steering wheel off.. i bought a non ADR complied one for lik $329.. then had to buy the $499 one which was approved.. now the stupid boss kit is screwed..
thanks guys for the help though... at least i now know whos ass to go kick.
There is a simple solution! I have found most boss kits to have smaller diameter pins than the factory (the pins cancel the indicators when the steering wheel rotates). The easiest solution is to slide some tubing with some reasonable thickness (1/4" silcon tubing or similar) over the pins and then reassemble. It should now work.
Hope this helps.
Cheers
Edited by BH_SLO32
I couldn't agree less with that
the best thing about big local suppliers is they *will* take back something that is wrong. Order the wrong bit from Nengun, wait 8 weeks before you realise, and see how you go returning it.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
