a common misconception. With any turbo timer that is properly installed the turbo timer will stop working if:
1. Handbrake is not on - why would be your handbrake be fully engaged in any sort of accident?
2. Brake pedal is pressed - who would not hit the brake in any variety of accident/incident
3. Keys are still in the ignition and the ignition is in the on position - unless you physically turn the car off with the keys the turbo timer will not run
So you could NOT have any variety of accident and the turbo timer keep the car running. It is IMPOSSIBLE (short of some catastrophic electrical failure).
Similarly with remote start. With a properly installed system the remote start will not function if:
1. Handbrake is not fully engaged
2. Gear selector is not in neutral (and yes these can/should be fitted to manuals)
3. Brake pedal is pressed
4. Car is put in gear at any stage
So how is remote start dangerous, and illegal? Makes no sense - where is ANY danger?
Oh, and yes Andy I agree - I love my window windup function on my alarm too!
+1
was just about to say that.. thats how mine functions, there's no ifs or buts about it.
remote start is cool i use it sometimes when getting ready to head out and cbf going outside.
i dont use i enough to pay extra for it if i had to but it does come in handy.
and the people with turbo timers and the people without, if your really leaving your car running long enough for someone to steal it (if thats what your worried about) then you put it down to 15, 30 seconds. even a hard bashing through the hills only needs 30 seconds to cool down if that.
and all name brand TT's that ive used and seen have extra wires hooked up to the handbrake, pedles and ingnition to make sure it doesnt keep running unless you want it too.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
