What Tyres Should I Run To Obtain Better 1/4 Times, Also Tyre Best Pressure?....help! :)
Hi guys,
I'll be running my car down the 1/4 in the next two weeks, its a r34 gt-t making about 200kw auto, now i have the choice of either running my works meister 18x10's on the rears which i wont be doing due to the fact i dont have $34923923 for another set of 18inch tyres :)
Now i can either run my standard r34 gt-t rims on the rear with summitomo 90% tread 235/40/r17's on the rear or i have a set of r33 rims which i can put some 16inch rubber on of my choise.
Now to obtain the best result down the quarter, what rims/tyres cobination would optimise my time, and also what is the best tyre pressure to put the tyres to?
Anyone with past experience your help is needed.
Thanks guys! :)
Personaly I have always been a fan of racing a car exactly as you drive it every day.
I do agree with you there, although i always get a bit tempted on the burnout pad before i run :D , so personally just dont want to ruin my perfectly good 18 inch tyres, would perfer to use my 17s or buy some decent rubber for the 16's, just need to know what combo/psi would be best.
Thanks :laugh:
do some googling ....
there is a formula to work out how to get maximum traction/responce from what size rims you run & tyres. with diff gears etc etc...
basically i was sort of explained to by a mate who worked it all out for his datto with a ca18 in it... that as a really rough guide you should be approximatly crossing the line at the top of your 1:1 gear. ie. 4th.
for me in my s15 its the top of 5th... but just realised yours is an auto...
so if you want more responce drop down to a 16" tyre with about 55 profile on it and loose some pressure out of it. should work great.
This is exactly what is needed and nothing more:
http://www.skylinesaustralia.com/forums/Mi...es-t204639.html
They would be great! but dont want to spend that much.
I've decided to run the 16's although still dont know what PSI to run them on, and also what profile tires to get. would 225/50/ZR16 be about right anyone suggest anything better? PLUS PSI, PSI,PSI common guys someone has to know whats best to run the tires on i always see people dropping tyre pressure. ;) It's not that much of a secret is it :banana: lol thanks guys.
If you have to buy tyres for your 16" rims than for an extra $100 you could get the above mentioned.
I can get good 2nd hand tires with reasonable tread for under $100 so $500 is a bit to steep. Thanks anyway mate.
Just need to know the best profile and psi to run :D
225/50/16 @ 28psi
Remember they are road tyres not drag radials so lowering the pressure won't have much/any effect on performance like a drag slick or radial would.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
