  • Replies 70
Posted Images
nope, I had one, leaned out at 280rwkw and above.
at 300rwkw, the afrs wouldn't go below 12.8:1, even with the injectors completely maxed in the power FC.
Have you seen the flow chart? Watch the blue line below 60psi.... Terrible!
Edited by The Mafia
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623796
mine saw the end of its performance @ 240-250rwkw
Walbro's are a mixed bag.
Sometimes they work, sometimes they dont... i wasnt even running upped rail pressures over normal conditions
There are FAR too many threads now with people and Walbros who have fuel issues.
I simply dont trust them. Have used Bosch for the lasf 4 years since.
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623867
mine was ok, just ran out of flow.
Remember the ratings -
Walboro 255 is 255lph at 40psi
Nismo 275lph is at 275lph at 70psi (What I have now)
Nismo is a perfect pump, drops straight in like factory, has a factory bracket, hoses and plug etc. I'll never touch a bosche.
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623933
and walbro rate there pumps at a voltage which isnt achieved in a "normal" car, sneaky haha
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623991
whats terrible about it? i dont look at fuel flow graphs often but it seems to flow a fair bit below 60psi? its above 60 that it really drops off. and why does more pressure result in less flow? i thought mroe pressure would mean more flow?
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3626197
yeah well think about it - rail pressure is 42psi + your boost (maybe 12psi?)
Thats a total of 54psi fuel pressure needed to drive the injectors. I don't know about you but thats putting the pump on edge and I wouldn't risk it.
Its a POS.
Actually, it was meant for NA applications..... Its pretty obvious..
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3626344
I am in the same dilema but I want something for 400-440wkw
My opinion is.... two walbros!!! Two walbros are cheaper than one 044! Here in Greece my mechanic said me that he saw many 044 to broke.. and aeromotive to broke...!! So he said me that with all pumps we have the danger to broke!
They broke either if you stay without fuel or if you leave the fuel for very long time (one aeromotive broke with the last way)!
If one of your two walbro damaged the other will work :D
So more safe!! :P
As I understand here in australian you don't use walbros... Here in Greece all people untill 500 fly hp use one walbro!
All are happy untill 500 with one walbro... too much scooby, evo etc!
After 500 you need a decent fuel setup as many people here told me what to do (surge tank solution with total 3 pumps)
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3626710
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
