  • Replies 70
Posted Images
nope, I had one, leaned out at 280rwkw and above.
at 300rwkw, the afrs wouldn't go below 12.8:1, even with the injectors completely maxed in the power FC.
Have you seen the flow chart? Watch the blue line below 60psi.... Terrible!
Edited by The Mafia
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623796
mine saw the end of its performance @ 240-250rwkw
Walbro's are a mixed bag.
Sometimes they work, sometimes they dont... i wasnt even running upped rail pressures over normal conditions
There are FAR too many threads now with people and Walbros who have fuel issues.
I simply dont trust them. Have used Bosch for the lasf 4 years since.
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623867
mine was ok, just ran out of flow.
Remember the ratings -
Walboro 255 is 255lph at 40psi
Nismo 275lph is at 275lph at 70psi (What I have now)
Nismo is a perfect pump, drops straight in like factory, has a factory bracket, hoses and plug etc. I'll never touch a bosche.
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623933
and walbro rate there pumps at a voltage which isnt achieved in a "normal" car, sneaky haha
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3623991
whats terrible about it? i dont look at fuel flow graphs often but it seems to flow a fair bit below 60psi? its above 60 that it really drops off. and why does more pressure result in less flow? i thought mroe pressure would mean more flow?
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3626197
yeah well think about it - rail pressure is 42psi + your boost (maybe 12psi?)
Thats a total of 54psi fuel pressure needed to drive the injectors. I don't know about you but thats putting the pump on edge and I wouldn't risk it.
Its a POS.
Actually, it was meant for NA applications..... Its pretty obvious..
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3626344
I am in the same dilema but I want something for 400-440wkw
My opinion is.... two walbros!!! Two walbros are cheaper than one 044! Here in Greece my mechanic said me that he saw many 044 to broke.. and aeromotive to broke...!! So he said me that with all pumps we have the danger to broke!
They broke either if you stay without fuel or if you leave the fuel for very long time (one aeromotive broke with the last way)!
If one of your two walbro damaged the other will work :D
So more safe!! :P
As I understand here in australian you don't use walbros... Here in Greece all people untill 500 fly hp use one walbro!
All are happy untill 500 with one walbro... too much scooby, evo etc!
After 500 you need a decent fuel setup as many people here told me what to do (surge tank solution with total 3 pumps)
https://www.sau.com.au/forums/topic/204507-walbro-255/#findComment-3626710
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
