Rb20 Looms, Rb25 Cam, Tyres, Chip, Cradle Bushes, Ignitor, Std Inlet Manifold, Throttle Body, Hub Mounts
Cleaning out the garage and found a few parts no longer required
Rear cradle bushes, whiteline set of 6 suit most nissans, used for a few months only before replaced with alloy ones, new $120 sell $40
Rb20 throttle body with TPS, $30
Rb25 starter loom, $15
R32 GTR rear hub mounts, alloy, exc condition, $40
RB20DET ignitor pack, $25
RB25DET inlet camshaft, R33 model, excelent condition $50
RB20DET inlet manifold- bottom half - perfect for a custom fab plenum on to be built on $30
2 x Dunlop 225/50/6 SPsport 9000 tyres, new new min 7mm tread, cost around $300 each new, $100 each
Dr Drift tuned chip to suit rb20 with 550 cc injectors, z32 afm and to4 size turbo, ran ok on my setup but this will change for each individual car, $20
All parts in good working order when removed, in Adelaide but will ship at buyers expense
Edited by Clint32
sorry i cant answer that for sure, do a search on here and you should find an answer
will the igniter work on a series 1 r33 rb25det if so sold to me
can you please tell me how much including frieght to postcode: 2228 in Sydney
i will take it
I have someone elso who wonts to buy the loom with that plug attached, so at this stage im waiting to hear back from him, failing that i would only sell the loom complete
hey iam after the o2 sensor but i need both ends off the plug awell if thats ok
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
