New part added,
Water pump - $50 (used, done 109 000Km, coming out of my R33 GTS4 RB25DE engine as I did major service today and replace it anyway. 100% WORKING) should fit any R33 without any drama I guess.
Gents
Got few things for sale
1. R33 stock Orginal standard shocks - $ 70 + postage
2. R33 Standard rear springs - $ 10 + postage
3. Rear strut tops, fulll kit - $40 + postage (you will need this if you are going back to normal shocks from coilovers.)
- SOLD
4. Water pump for R33 (Coming out of my R33 GTS4 RB25DE, has done 109 000Km), nothing wrong with it, just did my major service and rplaced it anyway) - $40 + postage
1. JIC coil overs, will suit R33 GTST (which i have been told by my Mechanic) R33 GTS4 (For sure), or R33 GTR(Front ones only) in good condition, not sure about the spring rate though, ride is Ireally stiff (Coming out of my r33 gts4) - $250.- SOLD
5. KENWOOD CD MD changer controll (AM/FM) - $30 + postage - SOLD
In case anyone wanted to know how to courier large exhaust system cheaply this kind of stuff, use FAstway couriers as it took only $44 for me to send it to Ingleburn which is 200Km from where I am, and toll quoted me $111 and others like $230
[color="#0000FF"]7.R33 Cat Back Exhaust 3.5" Pipe 4.5" Tip All Stainles Stell, FGK (Fujutsubo Giken) -SOLD [/color]
[/size][/size]
*************All offers will be considered. PM *******
located in Sydney- Kellyville, will post
Gents
- SOLD
- SOLD
[/size][/size]
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
