  • Replies 123
Just saw petrol for $1.70 this is an out of control
the petrol stations have to tell the regulatory bodies the day before what there price will be at 2pm the next day
So always fill up tuesday or before 2pm wednesday
its getting ridiculous but everyone is still paying it no one wants an electric car yet!
my 2c
yeah...there was an attack on a off shore refinery in Nigeria yesterday
Shell shut down production of it, so Nigeria has lost 10% of its oil production...
im guessing Nigeria's oil production makes up a small percentage of world oil production, so why does this isolated incident have world wide consequences???
any excuse to raise prices is used....bs
blah!!! :(
This is getting ridiculous seriously, they find any lil reason to bump the price of fuel up its so over priced at the moment, i heard a segment on TV saying fuel is really worth 80c per litre, but the mark up is 100%.. is everyone whos in power blind ?
and they say inflation is gonna kill us, thats if petrol prices dont starve us to death.
im seriously considering getting a aprilia 125 just for a lil cruiser.
I just full tanked. 138 bucks. like . WTF !
MRXTCZ
Hmmm, Dunno if there's anything to it...
but I notice at a few servos when you want to make the payment an even amount say $20/$30/$40etc
the pump will got to X0.01c no matter how lightly you touch the pump nozzle,
I even purposely stopped at 29.99 and only SLIGHTLY touched the nozzle, went straight to $30.01
conspiracy theory or another way we're gettin stooged? :)
Either way don't faze me, perks of a company fuel card :)
Edited by Yo-Yo
considering the track day for wakie took 3.5 tanks of fuel to get there, go around the track and drive back.and don't forget the 20l jerry can. think i spent 285.60 it worked out to be for 3 days
blah!!! :)
They should send us out there to protect all the refineries!! :)
Hey Moo did you end up finding out how much a trailer would cost for a day or two? i think i need one for next track day lol
conspiracy theory or another way we're gettin stooged? :(
Rounding mate.... its the work of geniuses
If you pay cash you can have 2c of free fuel! just fill to $30.02 and give them 30 bucks....
amazing isnt it
fill to $30.03 and your f**ked may as well fill to $30.07 and cough up that 5 cents!
Although pay on card and your mc f**ked
amazing isnt it
well yeah I realise that,
majority of people would pay on credit or EFTPOS though,
my point is why it's seems so difficult to make it an even amount at the pump, it'll instantly jump that extra cent
just pisses me off because I have a company fuel card so I'm getting ripped off that 0.01c when I fill up...
but like I said it's neither here nor there because I'm lucky in that they supply me a fuel card
like F*k I could afford to fill up two gas guzzling cars on my own
Edited by Yo-Yo
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
