Vic: R34 Gt-t Rims, R34 Xennon Headlight, R34 Standard Side Mount Intercooler,fan Clutch, R34 Quarter Panel & Ps2
Hi guys i have a few parts off my r34 for sale which i don't need anymore;
1 x Original PS2 No Mod Chip, Not Slim line, comes with all cables and one original ps2 controller $100ono
1 x Set 4 Original R34 gt-t rims and tires, excellent example cosmetically very good, although one wheel has slight scuff mark as shown in the photo nothing major, other than that great set. Tires included are Japanese Sumitomo HTRZ II 235/45/zr17 with 85% these tires alone were purchased for $600 brand new about 9months ago. $550ono
Will fit r32 ,r33 and non turbo r34's from what im told may fit other models, but please check before you buy.
1 x LHS Original R34 Xennon headlight comes complete with globe and transistors. Excellent working condition, although there was some cosmetic damage done to the bottom of the light as i bought a pair and only required one rhs light. Have repaired bottom of light with silicon as seen in pic, cosmetic condition not perfect, although will look pretty good andunnoticeable if placed on the car. Mechanical wise A1. $550
1 x R34 Standard Factory side mount intercooler with piping, great for upgrade for r32 or r33. $170ono On Hold
1 x R34 GT-T Fan clutch removed off car due to upgraded to a twin thermo system, engine only 70,000k. $50ono
1 x RHS R34 Quarter panel will fit 2 door or 4 door. Damaged slightly $50.
Parts can be picked up from northern suburbs melbourne, thomastown. May be willing to send interstate at buyers cost.
You can contact me via pm as im regularly on the computer, and will reply promptly.
Thanks guys! :banana:
Edited by DRFT31
Still all for sale guys!
Anyone interested in anything pm me :laughing-smiley-014:
Thanks.
Prices are neg guys, need this stuff gone. Bummp :nyaanyaa: everything still avaiable.
Edited by DRFT31
would u sell wheels without tyres or less?
sorry just realised your in vic,im in briss.
Edited by 51IPP
Will sell rims and tyres together not willing to seperate, everything still avaiable guys....
Edited by DRFT31
  • 4 weeks later...
Pm's all replied, everything still available. Please pm any interest. Thanks! :laughing-smiley-014:
Radiator Shroud SOLD! Common guys everything else still available! Anyone interested please pm me. Thanks!
***********New item added. R34 GT-T Front Pipe, Stainless Steal. More info 1st post************
:D
**********PRICE DROPPED ON ALL ITEMS************
May be willing to trade for PS3, through me your offers guys. If your serious! Please no more time wasters!
I pm'd you a couple of times regarding the rims as I was very interested, but you never replied.
I will grab your cooler of you matey. Please send me an email to me at [email protected] with banking details and pickup etc.
what happened to the other headlight? id love to buy a pair
Only the one headlight for sale, as my friend needed the one headlight for his car as had his had some internal damage. At the time could not find the headlight which he was after hence the one headlight now, as he bought a pair. Let me know if your interested.
Everything still for sale guys.
Intercooler back for sale as sale feel through.
PS2 SOLD!
Everything else still up for sale.***** R34 XENON Headlight on ebay now 2 days to go, grab a bargain.****
Pm me with any enquirers! Thanks! :D
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
