Hey all thought i'd throw up some pic's of my one8 i'm trying to get together for the 08 vicdrift series.
Turbo is trust TD06 L2
stock donk
solid urethane mounts
trust sump
blah blah wank wank heres the pic's
red one8
L2 biarch!
intake pipe.....probably could have done a few cuts to make it look more "custom fabed" but i'm a lazy sod!
I mounted the cooler and rad behind the rad support to decrease piping lengtht and prevent damage to those systems in the event of a little "nudge" lol
I also mounted the AFM (GTR nismo) in the throttle body side of the piping so it dosn't get affected by the remission "flutter" that would normally blow back past it on closed throttle. and because BEN told me to put it there.....lol
i was quite nervous taking apart the nismo AFM......put it still works fine. yay!
https://www.sau.com.au/forums/topic/204905-new-drift-one8-for-08/
from the front...you can see the brackets that hold the intercooler up level with the top of the rad.this setup also makes for easy ducting!
the AFM mounted in its new little home
the piping on the hot side shal be a bit easier.......once again my lazyness playing a part here..
gunna need to weld a bend onto the turbo.....will look neater and wont "pop off" under hard boost and high temps.....as they like to do.
wasn't real keen taking a hack saw to my NEW trust L2 either!
but it worked out ok.........if you do this remember to let it cool down very slowly.....i rapped it in a blanket straight after welding.
cooler brackets....
rusty bit of angle iron for the rad support underneath....
Because the rad is now so close to the motor i need to make the rad piping to suit......actually i should say "we"...my house mate is the welder.....i just cut and tell him what i want...lol
just to confuse you here's the gearbox mount.......didn't see that coming did ya?
gotta silicon the AFM top back on to keep out the nasties..
starting to come together..
The rad piping.....like all drifters/home owners i'm broke so am to "tight" to buy pretty silicon for the rad...
the bottom line proved to be more of a head ache to make than its worth........but i had already cut up the original to join the top line. :D
this bit= not worth the pain! keep your stock one or if you must upgrade buy a silicon one!
I'll prob put up some more pic's later......so check back
Cheers Waz
Looks great Warwick.
is that a Cast elbow welded onto the compressor housing? where from?
love builds like this over the normal bolt on style stuff, so much more rewarding.
only thing i would have done different is have the AFM box under the pipe - or is it too close to the fan ?
edit : few days on a polishing wheel and the will look amazing
yeah the fan is close.....but so is the bonnet when shut either way if you were gunna do this be sure to check clearences first.
If ya look close in this one you can see the engine mounts....solid as a rock....stearing wheel vibrates a little.....just adds to the feel.
got my seats and pimp fur in as well! yay
this is the car before i bought it....a long time ago.......Trents old car i believe....It has street cred as it has be thrashed by a D1 driver.... lol
I still have to make a custom oil catch can and a rad over flow bottle...coming soon
spaced the bonnet up as i'm a tight ass and cant afford a vented fibre glass one.
close up of the bend and hot pipe.....i cut down the bend and the turbo housing to make the bend look tighter.
The radiator i bought from JUST JAP leaked like a cive! from around the cap fitting so i ripped it off and welded on a speedflow item! much better.
Finished piping pic...still need overflow and catch can....
just enough room to fit my temp gauge sensor.
Brake booster stopper....sard 550 injectors
im not sure how the sr20's are in this area, but the step down on the oil breather i would avoid - reduce anychance of a restriction pressurising the motor -
rb25's dont like too small piping on the breathers
I have fitted a power bond under size harmonic balancer to reduce cavitation in the water pump and powerstearing issue's. I also fitted a Trust sump for extra oil cappacity.
sparco wheel and pedals, cusco hand brake grip, water temp,oil pressure and boost gauge fitted.
closer look at the finshed hot pipe side.
  • 2 months later...
Nice work on the pipes bit late know but for next time try useing spun donut's for those really tight rad's save doing all tose lobster back joint and welds if you need to know were to get them pm me back and I'll send you in right direction
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
