whats that?
watch ignition dvd vol 18 for last hot spot at Hillaries boat harbour :)
everyone parks up and waits for cops to come /block off carpark / defect as many cars as possible
all because there will be 1 or 2 D***HEADS who just have to do burnouts etc
https://www.sau.com.au/forums/topic/205570-hot-spotz/#findComment-3638786
And have some drinks & throw the bottles at the cop cars.
Then blame it on people coming from the pub. :P
https://www.sau.com.au/forums/topic/205570-hot-spotz/#findComment-3638936
they probly wont be able to sticker me as i will probly still have my sticker thats on there now
Could you put a false sticker on your window to make the cops think you've been defected? That way they won't bother defecting you again? Would that work? Keep it off most of the time, just put it up when you see the cops arrive or something.
https://www.sau.com.au/forums/topic/205570-hot-spotz/#findComment-3639173
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
