Just purchased a Canon EOS 400D with twin lense kit for $995 from Ted's Cameras (discount from $1090~)
Came with a free canon EOS carry case.
This photo was taken in auto mode. Will learn slowly how to do it all manually :D
  • 1 month later...
I know this is an old thread but yeah.
I sell all these cameras and the canons are probably the best camera in in my opinion.
I have the 400D myself but i spent the extra money and got the twin IS kit. (has slightly better lenses and they are image stabilized) also some nice lenses for starts is a 50mm prime lens (50mm f/1.8 is a nice one it has a nice wide aperture for nice depth of field effects and lets lots of light in low light conditions. and only retails for $149 come see me at JBhi fi strathpine :P )
The 450D has been short stock because of the limited stock of the 50-250mm IS lens there is plenty of stock of the camera and 18-50 IS lens. this shortage ends at the end of this month. Also the new 1000D gets release the last week of august maybe wont reach stores until the first week of september.
Anyways i just felt like typing all of this.
for all the new people learning about SLR's canon have a nice tutorial on there site.
Teaches you a little about Tv Av and manual modes on your camera.
Try this link : http://www.canon.com.au/eos/tips/shootingpanoramas.aspx
Have a good time with your cameras guys
Have a good one
Mitchell
I have the 400D myself but i spent the extra money and got the twin IS kit. (has slightly better lenses and they are image stabilized) also some nice lenses for starts is a 50mm prime lens (50mm f/1.8 is a nice one it has a nice wide aperture for nice depth of field effects and lets lots of light in low light conditions. and only retails for $149 come see me at JBhi fi strathpine :( )
Have a good one
Mitchell
Hey there,
The camera I currently use is also a Canon 400D - great camera I will say, but unfortunately it isn't my own - i wish.
At the end of the year I'm looking to buy my own. Iwas thinking to possibly just buy the same model as I have been really happy with it, but what do you think I would be better off with, the 400D or the 450D?
They are both within my price range, just wondering on your opinions. I know the 450D has live view, which can be a bonus, but I have gotten so used to not having one, coming from a point-and-shoot Canon digital camera.
Cheers :P
hey fullyhyper
Just to let you know that the 400D no longer exists. it gets replaced with the 1000D at the end of this month. check out the canon website for the 1000D :D
the 1000D is practially the same as the 400D however it has
live view,
uses the digic III processor,
sd card instead of CF card,
only 7 points of AF and a couple of other minor changes.
It is also rumoured to retail at under $1000
IMO though live view on a SLR is a waste of time... kinda defeats the purpose of SLR camera's.
heck out the 1000D though mate. it looks nice for a entry level camera :ermm:
I checked out the 1000D, looks like a good camera, and not much different to the 450D either.
A great website my dad showed me, for checking out camera's is DP Review.
Did a comparison of the 2 cameras, and only slight changes between them.
http://www.dpreview.com/reviews/compare_po...0d&show=all
Now i just have to figure out which one to get :D
The reason they released the 1000D is to introduce entry level SLR camera's into the consumer market.
Its very basic in SLR standards like all Entry level cameras. but the 1000D will eat all over the high end point and shoots.
So for people who want a fully auto camera but also want the speed + accuracy = 1000D (also then later on when they learn more about cameras they can experiment :banana:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
