Drought Action Day - Friday 15 Feb
Again this year, Safeway will donate all profits made at their supermarkets on Friday 15 Feb to help the Australian farming community.
More info - http://woolworthsdroughtaction.com.au/
Its a great cause and lots of people out there need our help.
So shop at Safeway sometime tomorrow and be part of helping fellow Australians & supporting this way of life.
Cheers all :P
https://www.sau.com.au/forums/topic/205980-drought-action-day-friday-15-feb/
:whistling::D
Maybe if those two companies didn't screw over farmers so much in the first place, and paid a fair price for Australian produce, rather trotting out the "we can get it cheaper from O/S, so we won't pay any more than $x" this sort of "day of action" wouldn't be needed.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
