HI all
I have this annoying clicking noise coming from behind my aircon unit when i start the car.
it happens for about 30 seconds then stops.
It is getting pretty annoying does anyone have the same problem? and if so how did you fix it?
its an r33 gts-t.
any help will be great.
Thanks
https://www.sau.com.au/forums/topic/206019-annoying-clicking-noise/
The clicking noise is from your Air Blend Servo motor (controls hot/cold mix). The gearteeth that control the flap have slipped off. It is really easy to fix, the only problem is removing the whole dash to get to it.
Easiest way is to make sure the heat is maxed all the way up, i.e. slam the red button a million times before u start the car (can be on or off), wont make the sound - leave it like that and wont happen again
hey jmaac
thanks for the advice.
would you know where abouts this blend motor is located on the unit
as due to my ever changin audio needs im somewhat of a pro at dash
removal now :whistling:.
and what to look for in the unit. will the gear be off or could it be that the
teeth have been shaved off.
Thanks
the teeth have basically worn down due to use, they skip over each other as they try to engage causing the click click noise.
i've currently pulled my dash apart to fix it. it's not a small task, at least a 3 hour job to take the dash out.
see attached, note the red arrow on the gear.
the blend door motor is located right in the middle of the dash, above the heater box.
same thing has happened to mine, after a few months im getting a very nast smell eveytime i turn up the heat. i then noticed a wet patch under the dash of the passanger side. If i fix the noise would i stop the damn thing from leaking?
Smell is normal, remove the glovebox and theres a panel which u can remove to clean aircon filter elements
This wet patch is bad, either means your heater coil has rusted out or a hose is broken (b/n firewall and heater)/hose clamp needs tightening (Unless condesations is somehow running back down into your car). U can tie off your heater in the engine bay and loop it around or fix it properly.
Im not sure if u can get replacement gear for these or one from a hobby shop to fit. I used a little glue and was able to build the gear back up, but it didnt last very long. If anyone manages to get a replacement (not 2nd hand) can u please let us know, I may make an plastic injection mould if not avail.
Noise has nothing to do with the leaking. The leaking is probably your heatercore, better to replace it sooner rather than later. The leak will only get worse, and where do you think that water is coming from? Your cooling system - better check and top it up :teehee:
You can bypass the heatercore if you like, just look for the 2 heater hoses going into the firewall on the passenger side, and connect them....
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
