you say china makes bad quality kits china has many provinces you just need to find the right manufacturer from the range of provinces
we had one kit we fitted to a rx7 and that kit was a poorly setup with no guide stoppers and poor design of strut and from installing that we learnt that more features had to be suited for this to perform better. we regurally visit the china trade shows and on our next visit we were able to find a better supplier/manufacturer for these lambo doors. we used this manufacturers setup and it worked out much better than the previous china setup
its not a case of china is bad its a matter of having contacts and be willing to put the effort out so that we can find the better product
my 2 cents
cheers
andrew
Totally agree with you mate, only said the ones we tried were no good, not every supplier in China wood be bad. Couldn`t possibly try every mnufacturer there is, just stopped looking when we found a good one.
  • Replies 159
im still considering writting up my howto on this.
Ive been waiting to take some more pics cause i have to pull it all apart again soon to fine tune the fitting.
Not sure but i think my drives side hydraulic strut is starting to wear already :P
For those who are installing these kits you need to be careful when opening doors. Ive managed to rip both my interior door cards.
yeah like craved said. you just need to ensure you open the door far enough out before u lift it up or it can catch on the black trim which runs around the top of the window
Yes need to open the door fully and then up. The shocks won`t be wearing they just have a break in period. They are first stiff, then get easier to lift up and down.
Hey, those doors look sweet. I'm hopefully going to buy an R33 Skyline within a week, i've already got a deposit on it. I just have one question, how much would one of these Lambo door kits cost me in Australian dollars? Also including shipping costs please.
Hey Terry i just noticed you said you were selling the Lambo Door Kits for the group price, are you still doing that? If you are then whats the difference in prices between a group price and a single price, i wasn't planning on getting a Lambo Door Kit too soon but if theres a decent difference in the price then i might.
If your putting the kit on your 32 please let us know how they turn out ...........
Does anyone know if R32's would have different bolt hole positions for the doors? my kit doesnt line up properly. its about 3.5mm out. so at the moment i have my car ripped apart in the shed completely undrivable until i put everything back on.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
