Three questions about turbo rebuilds. Sorry if they have been answered previously but I did a search and could not find anything on the first couple of pages.
1. I know that you can't rebuild ball bearing turbos, but can you keep the old housing and put all new internals in? Even if this saved me only $50-100 on a new housing I think I would prefer to do this.
2. I don't know if my old turbo is sleeve or ball bearing. Does anyone know the rough price differences to rebuilding a sleeve bearing turbo and putting all new internals into an old housing, assuming question 1 is possible?
3. If there are no identifying marks on my old turbo, is there a way to find out what size the turbine and compressors are? Just for curiosity's sake, especially if I can rebuild it with the same wheels.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/
With HKS turbos you need to buy the cartridge complete, then fit your own compressor and turbine housings - not too sure about putting the wheels you have on a garrett centre, sorry. A HKS cartridge expect to pay from about $1400 direct from japan.
Bush bearing rebuild kits are only a few hundered dollars by comparison, so alot cheaper.
As for identifying your turbo - wouldnt have a clue if its got no markings.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-433867
Tony, pm me details.
I don't know what I did to the turbo, it just gradually started making more and more noise over the past 6 months or so. The guys at Hills said it could be either the wastegate or turbo bearings, but I'm not losing any power so fingers crossed it's just the wastegate. I'm planning for worst case scenario regardless. He said the whole thing looked like a bodgy job so they might not have installed any of it properly.
Steve, the turbo is Garrett, is there something similar you can get for Garrett turbos? Whether locally or from Japan.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-433891
How much does it cost to remove and replace a turbo? If it can be done in an hour, I'll pay that to have the old one put back in until I can find a replacement. But if it's a 4 hour job or more, then I'm in trouble.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-434309
You should give GCG a call. I too have a damaged HKS GT3037S ball bearing turbo, and was under the impression that BB turbos could not be repaired - until recently. My turbo have a damaged turbine wheel and I have talked to GCG and they said that they have repaired several (over 100) BB turbos in the past with 100% success rate. I am hoping to send my turbo to them (or Garrett in Sydney) soon to see if it can be repaired. There seems to be some hope in repairing BB turbos. The initial thoughts were that it wasn't possible to buy trims separately, but some companies have said that you can!? Not really sure, but I will send my turbo to Garrett (dealer in Australia) to see what they say. Hope it can be fixed...
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-434344
Do you have a ballpark figure for how much they cost to repair? If it's over a grand, I'm tempted just to buy a near-new second hand unit for around $1k to save on delays on getting the car back on the road. But if it's only half that, then that sounds like a better option.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-434353
I did ask them for a rough quote but they won't quote you until you actually bring the turbo in. Then they'll strip the turbo down and see if it can be repaired, if it can be then they will give you an accurate quote.
They will however provide a free quote, and as you're in Sydney it would be worthwhile to drop the turbo in to GCG or even better Garrett to see if it can be repaired.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-434378
Originally posted by EVOIV
I guess you could measure the compressor and turbine trim to see what size they are? As for the A/R ratio, that's a bit more difficult :)
Hmm, I was lucky and found the AR ratio stamped onto the housing :) But you can also work out the AR ratio (roughly) by measuring the diameter of the intake and the distance from the middle of the turbo to the middle of the intake. Probably hard to do very precisely but good enough for a rough idea.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-437920
Ok, bit of an update.
Since the turbo is Garrett, I took it to Garrett in Chipping Norton. The guy there had a look and told me that the small side-to-side play was completely normal, and that the axial play was the only direction in which there should be no movement. He checked the housing for evidence of the wheels touching and there was none.
So he went to the wastegate, and found that at some point in the turbo's life someone had welded it shut. Presumably after they decided this was a bad idea they cut the weld off. But because of the welding dags still present on the pivot, it was sticking open and rattling around. I believe that this is the noise (it made the same noise I heard when he moved it around), so I asked them to fix it. I should get the turbo back on Wednesday.
He also said he could do a full rebuild for only $345 because it's a sleeve bearing turbo. While this is pretty cheap, I've decided that it only takes me a couple of hours to get the turbo off so I'll rebuild it when I start getting axial play in the bearing.
Now that I know how to check a turbo for wear, I'll include the check as part of my regular servicing.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-439049
I think they make both types. The guy at the workshop knew at first glance that it was a sleeve bearing. Either way, I'm sold on sleeve bearings now. The price of rebuilding them is ridiculously cheap.
https://www.sau.com.au/forums/topic/20699-turbo-rebuilds/#findComment-439148
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
