my advice. don't worry about the coils or ign amplifier unless you need them. once the car is being tuned it will be obvious if you are having any ignition problems.
as for the balancer, ideally you would have had the whole assembley balanced together (completel with balancer and flywheel). if your current engine was built and balanced with the standard balancer then just use that. but I would say keep revs under 8,000. you should be able to make plenty of power even with an 8,000 limit and your engine will live a long time.
and yes, the HKS R33 drag car used standard coils. the veilside R32 GTR drag car also used standard coils. the reason people switch to splitfires is that their standard coils eventually fail when they get old, and replacing them with new nissan ones is 3 times the price of splitfires.
oh, and personally I wouldn't put the XS mani and especially the XS gate anywhere near an engine like that. use the mani if you have to, but buy a better gate. I've seen guys with cheap gates have all sorts of problems.
Hmmm I bought the gate and the manifold.. the manifold I will improve its stength with brackets.... the gate if it makes me any problem I will through at recycle bin :O
Do you know the problems of xs gates? I read many bad comments... and many good comments.... some people say that they doesn't work and some people that they work fine.... we will see :D
buying a mani and then having to strengthen and modify it duznt tell you something??? One workshop told me the very same mani destroying a new turbo. A piece of weld broke off from inside and got sucked up through the turbo.
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
