k people i have just put a rb25det out of a stagea whole thikng works fine apart form the idle its lumpy and all over the shop i have so far narrowed it down to the coolant temp sensor cause when i unplugg it it works better liek picks up the revs if i have a small bend in the hose for one of the i think heater lines would that effect it
i need help on this one im not sure what else to do if i unplugg the wire it wont start with it off but runs fine if you unplug it if already running
where else should i be looking
CAS
im lost someone help me no mech can help me cause i live in the sticks (mildura) poo
Edited by teazn_r33
https://www.sau.com.au/forums/topic/207245-lumpy-idle-in-my-rb25det/
im not 100% on this but... if the coolant temp sensor isnt working and just tells the ecu the car is cold, then it puts more fuel in. so in your case, the ecu might be thinking the engine is still cold so adds more fuel and is slightly flooding it.
make sence?
CJ
This is what I'm thinking also, see if you can borrow a working temp sensor and check if yours is stuffed.
make sence?
CJ
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
