omg uleh.. what happened to Campsie habib? :)
You moved from Little Lebanon to Little Greece.. :P
Good move. kinda...
is nice... i like..
That's when I see him too but always on my bike so he doesn't see me. Psst, the other day when I saw him the car was dirty. Pass it on. Don't tell who told you.
shut uuuuuuuuuuuuuuuuuuup!!
my car is NEVER dirty.
Mars - i seen you car heaps of times mate around 6 pm from rockdale to brighton..do you finish work around that time?
guilty!!
I'm a resident and i can tell you that if you do the right thing when you drive through, you should be fine...
Yeah most of the time, except for the time i was driving through there, minding my own businsess, at 5am, and got pulled over and defected for the most bullshit reasons such as; airbox too shiney, too many k's on odo, no muffler
Now, it was 6am by the time they were done, the damn sun was on its way up, it had been raining, and i was f ing tired:
Airbox is an ARC airbox (so yeah its shiny but its enclosed and not a pod so thats bullshit)
Odo - does a truck get in trouble for having lots of k's on it? I dont think so. The owner before me rewound the k's and stuffed the odo, gee, dont hear of that with imports.......
Muffler - the cops didnt want to get their uniforms dirty by bending down on the ground to see if there was a muffler so they wrote me up for it anyway. Yes they actually said that. I have a muffler.
What a croc
Although i have to say that was nearly 2 years ago, and since then i havnt had any issues around there
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
