Ok after hours of research and even more time spent under the bonnet im calling for help
My cars idle is at around 1200-1300rpm once warmed up(was like it since i bought the car 3 months ago) r33 RB25DET motor
Mods:
exhaust
filter
fmic
walbro pump and sard press reg
stock bov
Now the acc valve screw is wound almost all the way in(i cleaned the acc valve by the way).The throttle body "stop" screw is untouched .The tps has been adjusted to .5v for closed throttle.There are no air leaks so to speak.
The cold start hose was blocked(once warmed up)to see if air is passing through the bi metallic thing(or is it the other way around??) and into the manifold but seems ok.
Now,if i crimp the inlet hose which runs to the acc valve the car will stall.... so thats where the air is coming from.If i disconnect the brown plug (on the solonoid) on the acc valve the car stalls.Now if i adjust the acc idle screw so that it idles at 750rpm ..i then reconnect the brown plug and bang up goes the idleto 1200-1300rpms.For some reason the brown plug
on the acc valve raises the rpm by around 500-600rpms (and even more when the aircon is switched on).Is this normal?
any ideas or help would be much appreciated
thanks
https://www.sau.com.au/forums/topic/207368-r33-idles-at-1200rpm-going-insane/
spring missing from aac valve, i.e. when removed is the valve able to be pressed in and spring back out on it own?
ecu could be f**ked causing 100% duty cycle meaning its fully open all the time or a short circuit to earth will do the same, so check the loom isn't shorted to earth on the ecu switched side/pulsed wire side.
if you have a multimeter that can measure duty cycle put it across the wires on the valve and see.
Edited by RB30-POWER
hi thankyou for replying.
yes the spring was in the acc valve and moving freely/nicely and seating correctly after i cleaned it.
The ecu is a factory one but has a mines racing sticker on it..
So i should put a multimeter across the wires on the acc valve brown plug at idle?
thankyou
only if it has duty cycle % measurement.
you can try and measure voltage, but the multimeter may not be fast enough.
if you measured voltage and it was 100% on you would measure full battery voltage, if you measured say 6-8v you would know the valve is being driven at less then 100% as it should be, it should be driven at almost 0% if the idle is higher then what its target value is. (very low voltage measured)
it will also target high idle if it thinks the coolant temperature is low as well, maybe there is no fault but it thinks the cars is cold and trying to target 1200rpm, does it uses much fuel blow smoke or runs fine? (check with consult would be ideal if you have access to it)
coolant temp sensor specs can also be found on this site and can be checked.
because from what you are describing, its not a vac leak, its whenever you hook up the aac valve its being driven 100% fully open, but why is what you need to find out.
i have just warmed up the car and measured the voltage across the acc valve solonoid plug (brown plug) and it gives a reading of 15v at idle.
The car is very heavy on fuel and the car smells rich even at idle.Even when the car is idling at 1200rpms i hear it (pop sound)but not loud but like a old carby car where it has been fully warmed up but the choke is still on if you know what i mean.
So if the temp sensor is giving an incorrect reading .. this can cause the car to idle high/run rich?
thankyou for your help much appreciated
the coolant temp sensor, acts as a choke so to speak, when the car is cold it needs more fuel and a higher idle to not stall.
if you give the ecu a false signal (like a faulty temp sensor), telling the ecu its cold it will run rich and have a high idle even if its actually warm.
the coolant temp sensor is the two pin connector alongside the single wire sensor (for dash guage) near the top radiator hose on the engine inlet manifold.
can you measure the voltage at the battery whilst the car is running at idle and also rev engine to 2000rpm and check the voltage.
15v is rather high, but it might just be the multimeter is low quality and not calibrated properly, if you rev it up and it doesn't go over 15V like at idle, we will assume its just a bad reading multimeter, if the voltage goes well over 15V it might have a faulty regulator in the alternator causing overcharging.
ok
well today i got myself another multimeter and checked the charging voltage and its just over 13v at the battery and doesnt change when the car is revved.
Now i measured the coolant temp sensor and it reads 22ohms when cold and around 3ohms when fully warmed up.
I also tried starting the car with the coolant temp sensor unplugged (as an experiment)and it struggled to idle but once i plugged it back it it idled up to around 1300-1400 rpms when cold and then drops back to 1200rpms once the cars fully warmed up.
i also checked the ignition timing too which was ok.
So im really at a loss as to why the car is idling so high... i guess my next step is to replace the ecu because i cannot think of anything else it could be.
The TPS is a 2-part component - a throttle position SWITCH and a throttle position SENSOR. The SWITCH part of the TPS needs 0 ohms across pins 1 & 2 (or 2 & 3) at throttle closed to tell the ECU that the throttle is closed.
Does the engine tend to hold revs on (up) gear changes? If it does, the the TPS(witch) is likely out of adjustment; the ECU should shut down the injectors when the throttle snaps shut during gear changes.
Hi,
yes there is a little bit of slack on the cable and the throttle body rests on the screw stop.
I do believe its an electrical sensor telling the computer something it shouldnt causing it to idle up (via the solonoid on the acc valve)
Blind elk.... i will have a look at that this afternoon as that is something i havent checked thankyou.Can the tps be adjusted for the throttle closed position?I remember adjusting the tps for 0.5v at idle using one of the 2 plugs attached to the tps.So do i measure the other plug on the tps for the throttle closed measurement?
oh ,the revs do come down between gears but not past 1200rpms
thankyou
Edited by r33gts4turbo
  • 1 month later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
