  • Replies 76
Bigger lines are usually for carbie-fed cars - ie those without any fuel pressure. With the hammer down on a carb'd car you can quickly empty out a 3/8" fuel line which is why many big HP carb'd cars run 1/2" lines or even bigger. But as Steve said, I've never heard of 600hp or even higher fuel injected cars needing bigger lines.
There was a 1000 hp GTR on Prestige Motorsport's mailing list recently and there is no mention of bigger fuel lines, just 2 044 pumps and 1000cc injectors. It's possible that he's running 2 fuel lines, or maybe the "HKS fuel delivery" is a bigger fuel line, but it's not very specific.
https://www.sau.com.au/forums/topic/20800-fuel-pumps/page/4/#findComment-498409
  • 3 weeks later...
I got some prices today from Repco Autoparts.
Bosch 910 (200L/hr) = $382.99
Bosch 975 (228L/hr) = $517.99
Bosch 984 (228L/hr) = $506.99
Bosch 044 (330L/hr) = $1113.99
I'm looking for an intank pump that can handle ~285rwkw (~200L/hr). I can order a Nismo 17042-RRS40 (246L/hr) delivered from www.greenline.jp for ~$370.
Can anyone suggest some places where I can find these pumps cheaper? As im looking to buy/fit 1 like asap.
https://www.sau.com.au/forums/topic/20800-fuel-pumps/page/4/#findComment-521741
Tony, do UAS re-use the old bracket or do they make their own up? And is that $440 installed and including extra fittings? If so that's a very good price for the pump, if you minus 1 hour's labour and ~$50 of fittings.
I'm seriously thinking of making my own bracket, and then give the plans out to anyone else interested in fitting a Bosch pump. I just need some motivation on the weekend, at a time where my fuel gauge is below the empty line.
https://www.sau.com.au/forums/topic/20800-fuel-pumps/page/4/#findComment-522563
woa! and to think people wouldn't part with $200 for my perfectly good 910.. silly people. Ended up giving up and just installing it myself :)
I have heard you can get the 910 for under $250 new, but this seems to be "I can get for $xxx, i give you $xxx for your pump".. not sure of the details of exactly where these people were talking about or whether they were full of crap.
The 910 is a 1-2 hour job, which might save you $200 in labour costs. It might be all you need depending on your HP goals. Its an easy job trust me - i'm not an expert.. but worked it all out fine. ..this is basically the install of the 910..its that easy:
044 seems to be a bit more involved, mainly because of the size of the friggin thing...
https://www.sau.com.au/forums/topic/20800-fuel-pumps/page/4/#findComment-522586
So the 910 fits straight into the standard bracket im assuming?
What extra parts are needed to make it all "work" ? From what I can see it looks like i'll just need a large clamp to fix it to the standard bracket ? and then connect all the standard parts back to it?
I want to get it all done and hooked up (will pay some if i have to) but at the momemt im getting no where.
https://www.sau.com.au/forums/topic/20800-fuel-pumps/page/4/#findComment-522625
Its not a straight fit, but with a hose clamp (as shown) it will be held very tightly into position. The only slightly difficult part was just figuring out a way to get the sock/filter back onto the new pump with the different size connector. I used 2x small hose clamps and a small bit of hose (as shown) to overcome that. After that you just slot the bracket back in, manouver it into place and put it all back together.
Maybe I should right a tutorial? although i think i saw one out there actually...
This thread goes into more detail of how to actually get into the tank.... http://www.skylinesaustralia.com/forums/sh...&threadid=18776
p.s. JimX.. hehe.. i love that site. Just having some fun with Horus here in melb :) If you met him you might spot the likeness..hehe
https://www.sau.com.au/forums/topic/20800-fuel-pumps/page/4/#findComment-522676
  • 6 months later...
